Complete noob question regarding safety
Discussion in 'Amp Tech Center' started by Doublechinmask, May 14, 2021.
  1. Doublechinmask
    Doublechinmask TDPRI Member
    Bosnia and Herzegovina
    Hey everyone.This morning i just wanted to check the tubes on my blackstar amp and once I unscrewed screws from cover the whole chassis fell out.I am too scared to return it back and screw it.What to do.
    https://ibb.co/4Sr5NFS
  2. wangdaning
    wangdaning TDPRI Member
    Wuxi
    Screw it back in? I mean, as long as you hold it by the chassis and avoid touching the circuit you should be fine. Make sure it is unplugged and check your tubes before you do it.
  3. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Remove the tubes before you reassemble it--otherwise you risk breaking them or damaging their pins or the tube sockets.
    The amp is designed to remove/replace the tubes without taking it apart. Use a small mirror to look up under/behind the chassis to help you get the tube's pins aligned with the sockets.
    Be gentle with the tubes; rock them very [very] slightly when removing and replacing them.
  4. Doublechinmask
    I did and now it makes no sound . I didnt touch anything.I am such an idiot holy cow.:(
  5. Doublechinmask
    I didnt change tubes at all.I just opened it up and returned it back.
  6. Doublechinmask
    It worked fine before...
  7. radiocaster
    europe
    Make sure the speaker is still connected, and also the power cable can move some in the socket and get disconnected.
    Lowerleftcoast likes this.
  8. john_cribbin
    john_cribbin Tele-Afflicted
    London
    It looks like the black lead to the speaker has come off.
  9. johnnylaw
    johnnylaw Tele-Afflicted
    New England
    Check the main fuse if your amp has one. I had this issue once on an amp that to a digger. It was the last thing I checked, of course.
  10. Doublechinmask
    Thank you guys for suggestion.I ll play it safe and let my friend who is amp tech to take a look.I am really scared of getting shocked.I know nothing about electricity
  11. john_cribbin
    London
    This looks like your problem:
    The black lead need to go back on the terminal on the speaker below the red one.
    Deathray likes this.
  12. OldPup
    OldPup Tele-Meister Ad Free Member
    Charlotte, NC
    Go easy on yourself. I would have been surprised as well if the chassis fell out of an amp I was taking the back panel off of. Put the amp on its side when you slide the chassis back in. Makes it way easier.
