"Compensated" 3 Saddle Brass Bridge Problems..Intonation Possible?
Discussion in 'Tele Home Depot' started by zanesaddiction, Dec 4, 2012.
  1. zanesaddiction
    zanesaddiction Tele-Meister
    South, GA
    My novice ears could hardly tell a difference in tone when I switched to this bridge from a 6 saddle type. Very soon after the grooves started appearing.
    This is what my saddles lined up to after intonation was set up as close as possible. The middle one definitely seems like it shouldn't be further beck than the low e and a saddle.
    Should I abandon this system or try those compensated nuts I heard about?
    What sort of problem will these grooves cause? Seems like they will be prone to "kinks" and cause tuning issues.
  2. waparker4
    Philadelphia, PA
    It looks like the middle saddle is on backwards
  3. ASC67
    ASC67 Friend of Leo's
    Minneapolis, MN.
    Yes, the middle one is backwards.
  4. crazydave911
    East Tennessee
    Apparently not................
    Although the bridge could be moved back a little ;)
  5. zanesaddiction
    South, GA
    it is possible that I mixed them all up whenever I took it apart. How can I be sure the right ones are on the correct strings? It's a little difficult to tell from the picture which ones are which.
  6. walleyeman
    walleyeman Tele-Holic
    Hills of Arkansas
    I wouldn't worry about the grooves. Have you seen vintage threaded saddles?
  7. dbickford
    dbickford Tele-Afflicted
    Morgan, Vermont
    Saddles ok. Scale length should be close to 25.5''. If that's true then your bridge should be moved back some
  8. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Um, if you flip the saddle around, it'll still be in the same orientation :lol:
    The saddles are on correctly.
  9. crazydave911
    East Tennessee
    :lol:, at least I was trying to be kind :D
  10. boris bubbanov
    New Orleans, LA + in the
    Zane, all three saddles are in their correct spots, you just have the D-G saddle screwed way way too far down. It should be equidistant between the two outboard saddles.
    Btw, the center saddle is odd out, the two outboard ones are clones of one another.
    You appear to have relicked the heck out of that bridgeplate. Did you apply something to the saddles, that could have softened them more than they already are? The brass on these cheapo Wilky Sung Il is I think real high in lead. And soft. You could go to a tougher brass, such as the Stew Mac # 5167 or if you wanna spend more, go to Bill Callaham's. His saddles are btw dedicated to each respective location. The Stew Mac # 5167s are totally interchangeable and can be flipped; reused on the other side.
  11. ASC67
    Minneapolis, MN.
    that's what happens when I post before my morning coffee kicks in :lol:
  12. zanesaddiction
    South, GA
    Yea , I had some fun with muratic acid relicing. The grooves appeared almost instantly after installation and before I reliced anything. And I did try putting the d and g saddle where it should be (right inbetween the outer two).
    What do you mean by "the center saddle is odd out"?
  13. justin72deluxe
    justin72deluxe Tele-Meister
    Oklahoma
    From the last picrure in the o.p. Switch the middle to the right, and the right saddle to the middle. I mixed mine up too the first time. Its esay to do. Mine now looks correct and intoneates pretty well, considering they are never perfect.
  14. dbickford
    Morgan, Vermont
    Wrong. Check the pic of the "relic" Wilkinson bridge compared to the pic of the new Wilkinson. Saddles are proper! Something else is the problem.
  15. Terminal Twang
    Terminal Twang TDPRI Member
    Cochrane Alberta
    I have a comment, but not about intonation.
    It looks like the bridge plate was notched for a b & g bender at one time? Is the wear from bender use in a previous life?
    I know that the "sharper angle" of compensated saddles wear fast when using a bender.
    I can also say that I've had to move my b string out of the worn groove before because it sounded dead; especially when bending the string (with the fret hand). Must be some burrs or something interfere after they wear a bit. Not sure, but an audible difference.
  16. zanesaddiction
    South, GA
    True. But, all the saddles are notched , not just the a, g, and b where the bender is.
    I'll probably try the Callaham brass or steel. They recommend stainless steel for benders.
  17. justin72deluxe
    Oklahoma
    You are correct. I was going off my unreliable memory, but i had mixed my saddles before.
    I agree he should check the scale length from the e saddle. Bridge placement could be off.
  18. Buckocaster51
    Iowa USA
    Admin Post
    I think the middle saddle needs to be turned around.
    It does have a "handedness."
  19. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    The Wilkinson Saddles are made so that the height adjusting screws will be perpendicular to the bridge plate when they are correctly oriented, You will notice the middle bridge's set screws are kicked forward on yours, thus an angle occurs as they meet the bridge plate…. that makes the G string just about lay flat across the machined part of the saddle...
    Or. . . Steve is right . . . flip the booger around an fuggidaboutit…
    Ron Kinr
  20. zanesaddiction
    South, GA
    I measured the saddles. The high E and b are at 25 1/2 ' . The low e , a are just about there. So, thankfully I (thankfully) won't need to be moving any bridges anywhere. I would be very surprised if the bridge placement was off. Both the neck and body are warmoth. (build thread) http://www.tdpri.com/forum/tele-hom...e-build-all-opinions-welcome.html#post4625763
    I am curious about Ronkirn's observation..." You will notice the middle bridge's set screws are kicked forward on yours, thus an angle occurs as they meet the bridge plate…. that makes the G string just about lay flat across the machined part of the saddle..."
    I can't see what he's describing exactly. But, he sounds convincing.
    But, I'm gonna try to "flip the booger around an fuggidaboutit" as he said.
