Coil split wiring help
Danb541
Raincaster, Oregon
I've wired lots of guitars but never with a split humbucker. I'm not sure where to ground these push pull pots. I'm guessing anywhere will work?
Here is the pots and a schematic.
nathan5782
Sacramento, California
Use the side of the pot or the flat surface of the push pull switch would probably be better. You can do an image search for a pre wired push pull wiring harness to get an idea of the setup.
moosie
Western Connecticut
I use the side of the pot, but the entire casing is electrically continuous, so whatever works without impeding action of pot or switch, and without hitting the cavity walls / bottom.
Danb541
Raincaster, Oregon
I didn't realize I had any responses. I wired it yesterday and it worked first try. I just grounded to the top of the box on the pot.
Thanks for the info
ToneCapMan
France
I did the wiring on a guitar for the first time this week & I'm no expert on electricity. Why is it important that you don't touch the wooden cavity wall? I was having problems actually because I had wires hitting the wall & when I organized everything so that the wires were touching nothing but air the problems went away, but I don't understand why....or even if that was the problem.
moosie
Western Connecticut
You can loosen connections, cause shorts, etc by squeezing too much stuff into the narrow cavity.
Worse, if you've shielded the cavity walls, whatever is touching will almost certainly short.
