Coil split & Killswitch
Discussion in 'Other T-Types and Partscasters' started by AznGuitarist31, Sep 22, 2018.
  1. AznGuitarist31
    AznGuitarist31 TDPRI Member
    Rochester, NY
    Hello everyone,
    I have a question about killswitches. Below is what my wiring is: DiMarzio D Activator bridge pickup into a coil split push pull with a killswitch. The black, white, green, and red wires from the d activator are wired according to the diagram. The killswitch I have into the middle lug and grounded to the bottom of the pot.
    For some reason it works backwards. I have 2 switches and tested both with an led and 9 volt. Both are NC switches. I've tried switching the leads of the killswitch and soldering it straight into the jack. All work backwards.
    No sound until buttn is presses. Can someone check out my wiring to see where I am going wrong?
