CNC routers and spindles
Discussion in 'The DIY Tool Shed' started by GunsOfBrixton, Nov 7, 2015.
  1. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
    I've used my touch pad with the .023 and .031 bits I have Robert , but I think I'll start using the same method as you suggest , its nerve wracking watching that small bit come down to the touch pad , I keep expecting to see it snap. If I get a chance tomorrow I want to cut a few test slots and see what width I get with a feeler gauge with these .021 bits.
  2. GunsOfBrixton
    GunsOfBrixton Tele-Afflicted
    Rochester, NY
    Herb, you ever get a chance to cut some fret slots with the .021" bit?
  3. adirondak5
    Long Island NY
    Not yet Robert :oops:, between the kids , a nasty virus that's made it through everybody in the house and good old tax time I haven't gotten around to it yet , hopefully this week
  4. telemcCaster
    telemcCaster Tele-Holic
    Michigan
    there's a little hint. You're going to zero your Z height on the spoil board. Or wherever you are going to zero it. Put the small cutter in the keep it slightly loose. Then jog down to the surface. Slowly until it touches. In the bit will slide. Stop jogging once it starts to slide. 0Z. Tighten the Collett.
    nickhofen likes this.
  5. rowka
    rowka Tele-Meister
    Jax, FL
    I plugged that little fret bit into my trial copy of GWizard.
    Here's what it says:
    Assuming 0.09 bit stickout (the length of the small tip diameter)
    Aggresive
    25000 RPM
    0.078 depth of cut
    9.7 IPM
    Conservative
    25000 RPM
    0.0782 depth of cut
    3.4 IPM
    Aggresive
    25000 RPM
    0.0142 depth of cut
    18.9 IPM
    Conservative
    25000 RPM
    0.0142 depth of cut
    3.4 IPM
    Aggresive
    25000 RPM
    0.0105 depth of cut
    21.1 IPM
    Conservative
    25000 RPM
    0.0105 depth of cut
    3.4 IPM
    What this is telling me is that the bit wants to travel at least 3.4 IMP at 25000 to maintain minimum chip loading.
    It can handle higher feed rates, but the depth of cut (and therefore deflection) is the limiting factor for the high end of the feed rates.
  6. rowka
    rowka Tele-Meister
    Jax, FL
    If I slow the RPMs, the feed rates also slow down, to preserve the minimum chip loading.
  7. Maxbra
    Maxbra Tele-Meister
    Sweden
    I´m thinking of upgrading my CNC with a new spindle. Currently using a makita (700w) and it works fine, but I kind of need it in the workshop, and I wouldn´t mind something with less noise..
    What do you think of this spindle from Tekno
    https://www.damencnc.com/en/milling-motors/teknomotor/hf-motor/1241
    Or should I go the "chinese" route?
    The above 0.6kw tekno is 2.8 kg and thats no problem. I know my machine can handle 1.2 kw chinese spindle, 3.5 kg
    I would love a 2.0kw with ER20, and economically it´s possible, but i really think it´s to heavy for my machine.. 5-6 kg
    I´ll need a VFD, some collets, brackets and tuning for either and thats fine, but I wish to stay under 7-800 € total.
    I guess my question is - Do I gain anything with a Tekno verus a stronger, chinese spindle, is the Tekno a superior product..?
