CNC Project - Going Offset
Discussion in 'The DIY Tool Shed' started by Washout, Feb 4, 2016.
  1. Washout
    Washout TDPRI Member
    Worcestershire, UK
    Hi all,
    I thought I'd introduce a project I'm currently undertaking to make as much of 2 Jaguars as my machine will allow.
    Part 1 - is the CAD and CAM side of things for the necks
    Part 2 - is a test of the CAM on plywood for the main neck body before attempting maple
    Part 3 - machining of the neck body in maple
    PeterUK likes this.
  2. Washout
    Worcestershire, UK
    Part 4 - making some body templates
    Part 5 - Machining the fingerboards (including fret slots)
    Part 6 - Machining neck clamping cauls and gluing the fingerboards
  3. guitarbuilder
    Everytime I click on a video I get an error.
  4. Washout
    Worcestershire, UK
    Hi Guitarbuilder
    Its working my end (using chrome) - let me see if I can get a url that doesn't display the video in a window - here try this one or the one on my signature - or do a Youtube search for the channel I_Made_This - let me know how you get on.
    https://www.youtube.com/user/CCWashout
  5. guitarbuilder
    That worked.
  6. Washout
    Worcestershire, UK
    Cool - hopefully they are of interest, although I appreciate the CAD/CAM in part 1 is a bit slow going. I also leave my mistakes/issues in so that others don't have to :)
    Cheers
    Chris
  7. guitarbuilder
    To be honest, I skimmed the neck one. I've been cnc-ing my own guitar parts for quite a few years now, so...well... I've done this sort of thing...:)
  8. Washout
    Worcestershire, UK
    No problems Marty, glad you had a look.
    With a post count that high, surely you must have a few "Complete Guitar Projects" by now ;)
    Mind you I have 3 incomplete guitar projects already, with CAD/CAM coming for two more (Andy Summers Telecaster just to see how close and under the original price tag I can get to the Custom Shop and another guitar of my own design).
  9. Guitar novice
    Guitar novice Tele-Afflicted
    Perth
    Hi Chris
    Thanks for posting this. Im using fusion 360 so im sure you saved me some cad frustration.
    Got through the first video. Looking forward to seeing the others on the weekend.
    Cheers
    Matthew
  10. Washout
    Worcestershire, UK
    Thanks for the feedback Matthew and glad you found the CAD/CAM video useful.
    Personally I found it slow going myself, but will likely start doing a CAD/CAM video followed by a video showing the machining itself, so that viewers can choose to skip to the chips flying part if they want, but still leave the more academic stuff to help people new to CAD.
    One area in Fusion 360 I (and others) struggle with are the multi axis curves on the neck/heel and neck/headstock transitions. I kind of stumbled on a partial solution by lofting, but Fusion seems to either be a bit clumsy in that area or I'm missing something (T-Splines are good but don't seem to mix well with parametric modelling).
    It should be long before the next part is up.
    Cheers
    Chris
  11. Washout
    Worcestershire, UK
    Part 7 - no CNC this week as I'm binding the fingerboards:
  12. Washout
    Worcestershire, UK
    Hi all,
    Parts 8a and 8b are up.
    8a is a walkthrough of Fusion 360 end to end and 8b the machining for the dot inlays on the neck:
  13. Washout
    Worcestershire, UK
    Part 9 is up - a CNC profile sanding block in Fusion 360 and then some fret work:
  14. Washout
    Worcestershire, UK
    No CNC in this video, but shows where I'm up to with the necks:
  15. Washout
    Worcestershire, UK
    Two videos this week, as I've finally got to the bodies:
    One probably not needed for the CNC veterans on the forum (i.e. machine setup):
    and the second some machining:
  16. telemcCaster
    telemcCaster Tele-Holic
    Michigan
    Very nice documentation. You really do A good presentation of your work.
    I have a few questions.
    What is the reason that you removed all of the material around the dots? Is that because you get better round stock? For example couldn't you just use a micro bit and route spiral passes around each dot line curve? I realize that you only had 20 dots to make but with that amount of stock you could easily make twice as many maybe more. Did your dots turned out absolutely around or are they faceted?
  17. telemcCaster
    Michigan
    The other question is have you ever used Rhino and a rhino plug-in for Cam like rhino Cam or mad cam? I would really be interested in your comparison if you have.
  18. Washout
    Worcestershire, UK
    Hi telemcCaster
    Thanks - I have a few mroe vids up which I'll post soon, but to answer your questions:
    I tend to use trochoidal/adaptive clearing wherever possible these days and it was partially as I'd never cut the material before to try it out. I could indeed have ramped down in a spiral around each dot and that would have been quicker/less material, but the difference would have been neglible - especially as I can ramp up the feeds and speeds on the adaptive strategy once I'm happy it will behave itself.
    As I run a full depth clean up contour pass after the roughing the circles are nice and round with no facets - Autodesk/Fusion 360 uses splines etc for curves and not rasters as far as I can make out.
    I've certainly heard of Rhino and certainly some of the guys on the MYCNCUK forums use it (one of my other online haunts), but I have not tried it myself and given the aforementioned adaptive clearing strategy in what is "free" software (within certain parameters) I'm likely to stick to Fusion 360 for the forseable future. I've used quite a few other CAD/CAM programs over the years e.g. Vectric, Sketchup, Maya, 3DS Max (and a bunch of game engine 3D packages, some of which are proprietry) and I think Fusion 360 is excellent. Its has some
    challenges, but with almost monthly updates from Autodesk it is getting really good and the integrated CAD to CAM workflow saves a huge amount of time especially when updating models.
    Hope that helps.
    Chris
  19. telemcCaster
    Michigan
    Yes it does. I have a friend in a position to get set up and I could not recommend f360 yet.
  20. telemcCaster
    Michigan
    Awaiting the new video
