Cloth covered wire?
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, Jun 18, 2018.
  1. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    What's the best way to deal with this stuff? My ends fray out and look a mess!
    swingtime likes this.
  2. drf64
    drf64 Poster Extraordinaire
    Ada, MI
    Don't strip it. Push back the ends to expose the wire
    Rayf_Brogan likes this.
  3. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    A small (small !) amount of CA glue can help to avoid that the braid be shred.
  4. Axis29
    Beaumont, CA
    Also, a sharp pari of dykes for cutting it is a plus.
  5. NICQ
    NICQ Tele-Meister
    Vienna/Austria
    I cut them back with a scissor/knife and then burn the frays with a lighter for 1 sec
    Jimmy Owen and zephyrR1 like this.
  6. Blue Bill
    Blue Bill Poster Extraordinaire
    I've used a small drop of clear lacquer, applied with a toothpick, to prevent fraying. It doesn't stick to the metal part as aggressively as CA glue. Avoid getting any glue on the wire part, or it could interfere with the electrical connection.
  7. boredguy6060
    boredguy6060 Poster Extraordinaire
    Sou Cal
    I cut the cloth with a razor, then push it back enough to make the connection.
  8. PinewoodRo
    PinewoodRo Tele-Afflicted
    Carmarthenshire, Wales.
    This works for me too.
  9. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    The "not vintage" but modern way to handle the fraying is to slip a short length of electrical shrink tube over the cloth insulation and push it back. Solder the joint. Go on to the next solder joint and do the same. When all wires are soldered in place, slip the tubes up to the joint and apply heat from a heat gun. Presto neato you're done. It's a clean professional looking solder joint. Not vintage looking though.
  10. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    I melt/burn the frayed threads with the soldering iron.
    Probably not recommended but it's addictive. :)
  11. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    All the above answers are correct, IME. I've got a few more. :D
    The drop of lacquer is good, but I find it's even better to let it dry and who has time? So where I have a bunch of wire, I'll spray a whole coil and let it dry before cutting or stripping any. For heaters, you can use clear lacquer on one and brown or black on the other -- aids in maintaining phase.
    Then: The wire matters. IMHO the vintage stuff Hoffman sells seems to be the best. Theoretically the cloth-over-PVC stuff should be better, but it's bulky and awkward and somehow hard to strip.
    And, if you have really sharp diagonal cutters to cut the wire and jacket cleanly (Hoffman sells some of these too) you can avoid stripping altogether *if* you can take advantage of the push-back feature. There are a few approaches:
    1. Push back say 5 mm, solder down say 2mm of wire, and slide the cloth back 3mm so it doesn't bunch up. Great for pot lugs, socket lugs, and other accessible, visible spots that need just a little wire to solder.
    2. Free the cloth over the length of the wire, slide it say a half inch off one end, cut off the half inch of jacket with sharp scissors, and recenter the cloth jacket to leave two quarter-inch stripped ends.
    3. On long runs, more than several inches, distribute the pushed-back cloth over the length of the run, so it doesn't look like a boa constrictor that swallowed a guinea pig.
    4. And for runs that go under the board, just make sure the guinea pig is out of sight.
    Where you must strip (I often do) wire strippers matter *a lot.* I've worked my way up to a pair that are very precise; they don't have a label on them, and I forget where I got 'em. Stripping action: Cut, then twist the strippers while holding them tightly closed, or alternatively, cut, hold, then twist the small length of cloth you're going to strip.
    Those two pesky strands of white inner thread? Despite all I've said, I sometimes still get 'em. Yeah, a lighter can burn them back flush with the cut. The trick is to just burn them, not the rest of the cloth. I have a 'Soto pocket torch' that focuses a gas-station lighter into a tight blue flame. Or sometimes a tiny pair of nail scissors (your wife can buy more) are even more precise and tidy. The scissors on a Swiss army penknife aren't bad.
    Mr Ridesglide likes this.
  12. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    SngleCoil likes this.
  13. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    I didn't find any trouble removing the insulation from the modern cloth wire, but I did find it was easy to nick the (solid core) wire. I had a couple break wires on me because I nicked them.
  14. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    Something like this is what I use and does a clean job on the cloth. 1529412989877.png
    Jimmy Owen likes this.
  15. SngleCoil
    SngleCoil Tele-Holic
    Charlotte, NC
    dfrosto likes this.
  16. Rayf_Brogan
    Rayf_Brogan Tele-Meister
    I didn't figure this out until I was soldering my very last wire on a Strat pickguard assembly.
  17. FenderGuy53
    FenderGuy53 Poster Extraordinaire
    Marion, NC
    ^^^ THIS ^^^
    ...and once you button up the control plate, you won't notice it!
  18. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    #2 is a really good trick. You can also use short bits of the cloth to slide over leads of axial caps etc. when they are in iffy places.
    King Fan likes this.
  19. red57strat
    red57strat Friend of Leo's Silver Supporter
    Massachusetts
    It also depends on the wire.
    I built an amp with cloth push back wire from Mojotone. It came out great with no fraying. It looked nice! No special techniques or tricks were required.
    On my next build, Mojotone was out of yellow so I bought it somewhere else. It frayed a lot. Looked kinda sloppy.
    I think the Mojotone wire might've been potted.
