Cleaning wax
Discussion in 'Tele Home Depot' started by HarpJim, Jun 13, 2009.
  1. HarpJim
    HarpJim Tele-Holic
    Hi guy! I just wax potted my first pickups and I'm wondering what do you use to remove the unwanted wax on the top and bottom of the pickup?
    Thanks
  2. JasonRobert
    JasonRobert Tele-Holic
    Paddock Wood, Kent, England
    I usually wipe it off with a paper towel as soon as possible (ie when they wont burn me...) if the wax is too hard to wipe off, then you could always pot with pickup again (just so the wax you want to remove is melted) and then take it out and wipe it (but oinly when it is cool because it will burn...)
  3. pirana
    pirana Tele-Meister
    A little denatured alcohol on the paper towel will help.
  4. HarpJim
    HarpJim Tele-Holic
    Ok thank you guys I'll give it a try!
  5. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    Hair dryer (-;
    That's what I use when I need to peel a wire off of a parafin/wax potted pu for repair or DCR calibration.
  6. HarpJim
    HarpJim Tele-Holic
    I didn't think a hair dryer would be hot enough! I'll give it a try!
    Thank you
  7. fishtownmike
    fishtownmike Tele-Meister
    Philadelphia
    Naptha!
  8. Nick JD
    Queensland, Australia
    If you want to remove all trace of wax, a mixture of tolulene and methyl ethyl ketone will dissolve every last bit.
