cleaning my gas grill
Discussion in 'Bad Dog Cafe' started by teleman1, Aug 5, 2021.
  1. teleman1
    teleman1 Friend of Leo's
    Arizona
    I used a razor blade & a spatula. I scraped a few cups of grease/grim. Question is, when cleaned, is it actually working better? More efficent?
  2. Bones
    Bones Telefied Ad Free Member
    Luddite Island, NY
    it will have a better chance of getting rusty, that's about it.
    Frodebro, Skydog1010 and getbent like this.
  3. JL_LI
    JL_LI Poster Extraordinaire
    Long Island, NY
    Grease and grime on the inside is a fire hazard. On the outside, it’s an eyesore. Soot on the inside cover retains heat. I periodically remove remove the drip tray and replace the insert and clean grease and grime from below the burners to minimize the chance of a fire inside the grill. I clean the outside with stainless steel cleaner after the grill cools. I leave the solids from smoke on the inside cover. I also regularly check hoses and connections. I replace anything that looks worn or damaged at the beginning of the season. Good maintenance helps the grill last longer.
    teleman1 likes this.
  4. Zoso420
    Zoso420 Tele-Meister
    Chicago
    Easier to clean while hot
    Skydog1010 likes this.
  5. stxrus
    stxrus Poster Extraordinaire
    St. Croix, USVI
    I can’t answer that but when I clean my gas Weber it doesn’t produce food that tastes the same. I’m a believer that, like a cast iron pan, cleaning a grill that doesn’t experience flare ups is a waste in many ways
    That’s just my opinion.
    teleman1, SRHmusic and Skydog1010 like this.
  6. telekaster1999
    telekaster1999 Tele-Afflicted
    Heath Springs SC.
    You lost me at gas.
    BB, Frodebro, Deeve and 2 others like this.
  7. stxrus
    St. Croix, USVI
    Put an ad in the paper. You may find yourself
    telekaster1999 likes this.
  8. TwangToInfinity
    TwangToInfinity Tele-Afflicted
    Twangville
    i scrape mine with a dollar store putty knife , i have the enameled cast iron grills with flat tops, then burnish it firmly with a crumpled tight brown paper bag.
    also i use a alcohol soaked qtip to draw out the soot from the spider screens
    sometimes i will use a vinegar soaked microfiber cloth to put the shine back to the top, i think when i bbq in the rain some solids or something cook on
  9. teleman1
    Arizona
    You mean like 110 degrees when I was doing it? LOL
    BB likes this.
  10. Zoso420
    Chicago
    No cooking temp hot
