Clean power testing a 6G2 Princeton on an oscilloscope
Discussion in 'Amp Tech Center' started by peteb, Nov 30, 2019.
  1. peteb
    peteb Friend of Leo's
    Cascadia
    Small wave
    Cross over distortion
    Saturation on the top and the bottom
    See how uneven the two halves are? Is this the uneven nature of the cathodyne phase inverter. Is the clipping in the PI?
    Taking it one step farther, is it saturation on top and cut off on the bottom, since the PI is not pushpull?
    It’s easy to see the size of the maximum clean wave as six grid lines, 5V per.
    The maximum wave is balanced.
    The maximum clean signal at the speaker, ignoring cross over distortion looks like 15 peak volts (calculated to be 10.6 RMs), measured 8.75 volts AC RMS on a DMM for 15 W or 10 W into a 7.5 ohm dummy load.
  2. D'tar
    D'tar Friend of Leo's
    WNY
    Maybe PI or perhaps your tubes are not a matched pair, no big deal. Scope the power tube grids to see if you have pi clipping.
    Swap tube to see if the harder clip moves with the tubes.
  3. peteb
    Cascadia
    Thanks Dtar. Those would be good tests.
    I think the small signal to bias ratio shows that the clipping is not in the power tubes.
    I don’t thing a 9-10 volt RMS signal is enough to make the tube saturate when the bias is -40 VDC.
    I wouldn’t be surprised if the power tubes had some mismatch. They are newer tungsols, and I have seen newer tungsols match and then not match after some use.
    Also, the wave looks very equal on both sides prior to clip. I don’t think they would so equal if there was a significant mismatch between the two power tubes.
  4. peteb
    Cascadia
    I take this back. Any PI only sees peaks and no valleys. Waves in Phase inverters are only subjected to saturation and not cut off.
