Classic 30 Speaker
Discussion in 'Amp Central Station' started by orange_crush, Jun 17, 2019.
  1. orange_crush
    orange_crush TDPRI Member
    canada
    Hey everyone, a while ago I posted saying I would be upgrading the speaker in my Peavey C30, that I was focused on Celestion but was there anything else I should have a look at.
    I've done my fair share of research and I think I'm an Eminence guy now. I have four choice in mind:
    Private Jack
    Red White and Blues
    Texas Heat
    The Governor
    I want something fairly warm with medium headroom and isn't going to sound too twangy in the highs like the Blue Marvel. Any help to narrow down my selection?
    Also, anyone know if either: the red white and blues comes in 16 ohms, or can I put an 8 ohm speaker in the c30?
  2. dougstrum
    dougstrum Tele-Holic
    blu ridge mtn cabin
    If you're an eminence guy I'd say try the gb128, but don't think they make 16ohm.
    Wgs et-65 is also nice.
    orange_crush likes this.
  3. RyCo1983
    RyCo1983 Tele-Afflicted Silver Supporter
    Central PA
    I had a C30 with an Emi Cannibus Rex in it. Fantastic. I love a hemp coned speaker.
  4. uriah1
    uriah1 Doctor of Teleocity Ad Free Member
    Around
    Had billions in mine at one time or other
    You might try an ET65..tad warmer than
    most.
    THere are thousands in the celestion, weber, emi, and Jensen camp.
    But I will skip those for now.
  5. orange_crush
    canada
    I like that a lot. Damn, I just have to pick one and go with it :D
  6. Dacious
    Dacious Poster Extraordinaire
    Godzone
    I'd steer clear of the British flavoured ones. Despite the EL84 tubes it's an American style amp.
  7. orange_crush
    canada
    Yeah I feel that. If the red white and blues came in 16 ohm I'd have one ordered.
  8. Dacious
    Godzone
    There's a 16 ohm Legend I think - the Sheffield speaker option in some of these was pretty fair too. But the CR is popular although I have no experience of it personally.
  9. fender4life
    fender4life Friend of Leo's
    los angeles
    I never had one, but the texas heat is a well liked speaker that is supposedly a bit dark. And thats what u r gonna need to cut down on the twang. Personally tho, i think thats never a good thing. Best IMO to use a speaker that is NOT dark or bright but more neutral, then cut brightness in other ways like tubes. JJs are pretty dark tubes and it might be a good idea to try one in V1, then if that doesn;'t do it put one in V2, then V3 if it still needs less twang. Then JJs in the power section will take it even futher in that direction.
    As for impedance, you CAN use an 8 in the C30 by switching the transformer to 8 ohms. But unlike most amps there is no impedence switch. What they do is make the speaker jack a switching jack so when you plug an extrenal 16 ohm cab in, the tranny is switched to 8 ohms via the switching jacks contacts. Since an external 16 ohm cab along with the internal 16 ohm speaker are then in parallel which makes for a 8 ohm load. So to switch it to 8 ohms just insert a dummy plug into the extention speaker jack. A angle plug will work well since it won't stick out. This would be ideal... http://store.haveinc.com/p-62619-fl...MIp4-g1dvw4gIVh7fACh1HRwLCEAQYBCABEgJQd_D_BwE
  10. vanr
    vanr Tele-Afflicted
    AZ
    You can special order the GB12 in 16 ohm. There is a small upcharge for doing so and it takes 2 or 3 weeks to get, but it can be had.
