Classic 30 Speaker Ohms
Discussion in 'Amp Tech Center' started by WrayGun, Nov 8, 2019 at 9:32 PM.
  1. WrayGun
    WrayGun Tele-Afflicted
    Pittsburgh, PA
    I’m hoping that someone who understands such things better than me can provide me some guidance on replacing the stock speaker in my Peavey Classic 30.
    I keep reading about options regarding extension speaker wiring tricks, allowing you to use different ohm ratings, yada yada.
    All I want is to pull out the original speaker, and replace it with a different one. Nothing tricky.
    So do I just look for 16 ohm replacement models, to just plug in and go?
    Sorry that this is undoubtedly a stupid question, but I need an answer that won’t confuse my simple brain.
  2. rolandson
    rolandson Tele-Meister
    Cascadia
    No such thing as a stupid question.
    Replace your speaker with one of the same parameters as the original....impedance and wattage rating. Observe polarity and bingo, done.
    Oh, as per power handling...that's a minimum...so if the original is rated for 50 watts and you want to use one rated for 100, no problem. One rated lower than the amp's output will probably be a problem.
  3. Tonetele
    South Australia
    Good point rolandson.
    I'd go for an 8 Ohm speaker.Easier to get another if needed in the future unless your amp is wired for a 16 Ohm speaker. I will say one thing though ,get a speaker at least twice the RMS output. So your looking at a 70 Watt speaker- probably not cheap. As to the brand /type you buy, I'll let others here make recommendations OR do your homework.
  4. Straydogger
    Straydogger Tele-Holic
    Western Pa.
  5. LightningPhil
    LightningPhil TDPRI Member
    Nottingham, UK
    While there might be less 16 ohm speakers out there, supply is still vast and won’t dry up.
    The mentioned Celestion g12 v-type is a good sounding and affordable speaker. The sound will warm up as it breaks in and it’s resonance drops. Takes a while though.
  6. rolandson
    Cascadia
    I've been very happy with what Eminence has to offer, some of which is rather affordable. They have a pretty wide selection of 16 ohm speakers.
  7. uriah1
    uriah1 Telefied Ad Free Member
    Around
    Ya. Other output good 8ohm. lot of blogs.
  8. joe_cpwe
    joe_cpwe Tele-Holic Silver Supporter
    I haven't done extensive shopping for a speaker for my Classic 30 but I have an Eminence legend GB128 that I prefer over the stock speaker. Although being 8ohms means using the ext jack. Not really an issue because it's plenty loud w/ one speaker.
  9. Henry Mars
    Henry Mars Tele-Afflicted
    Bucks Co. PA
    The amp is 30W. You need a 50W (min) 16ohm 12'' speaker. Almost anything would be better than the stock speakers they use now. If you want real clean go with a speaker with a sensitivity of 98db/WM or higher. Warehouse or Eminence have a good selection. Speakers are personal preference so I won't recommend one. The two speakers I use the most (but not exclusively) are the C.Rex and G12H. They just fit my style. YMMV.
  10. uriah1
    Around
    FYI. Ext jack for internal speaker at 8. Not additional. Imho FYI
    C30 good with any. Try creamback. Don’t use internal for 8ohm new combo speaker.
  11. 1300 E Valencia
    Fullerton CA
    The original internal speaker is 16 ohms.
  12. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Original speaker is 16 ohms, I'd stick with that. "Hard to find" is a bit silly, it's not like you have to go prospecting with a mule. Just shop around, order the speaker you like in 16 ohms. Most are available in 8 or 16, it's not an uncommon thing,
  13. WrayGun
    Pittsburgh, PA
    Thanks yinz guys!
  14. WrayGun
    Pittsburgh, PA
    What would be a potentially good choice for a Billy Gibbons “Cheap Sunglasses” lead guitar kind of sound? Recommendations really help :)
  15. vanr
    vanr Tele-Afflicted
    AZ
    Stock speaker is 16 ohms. External speaker/cab needs to be 16 ohms also. When you plug a cabinet into the external speaker jack the amp switches to an 8 ohm load.
