andrewRneumann
Hello fellow nerds and geeks,
I've been trying to design a P-P power amp that drives a pair of 6V6S's (triode-strapped) as far into Class AB2 as possible. My research convinced me that the CF drivers need to be direct-coupled to the grids of 6V6 to provide the pulses of current required and also avoid blocking distortion. This causes quite a lot of havoc when it comes to biasing the whole setup.
There are different ways and places the bias could be applied, but it seemed best to apply a negative bias on the tail of the CF driver. This would have to be a low impedance bias source because it pulls DC while in operation, so that pretty much forces me to use the 50v (70VDC) bias tap directly (with diode and smoothing cap) with no voltage divider network.
Then to get the correct bias on the power tube, I had to go ahead and add some tail resistance. So this makes the power tube have a mixed fixed/cathode bias.
I'm totally in the weeds on this, and hoping what I've designed makes sense to somebody out there and my errors can be pointed out. Attached diagram is just one half of the P-P setup. Also if anyone can point me to a working schematic with a similar design, I'd much appreciate it.
