CL $49 value
Discussion in 'Bad Dog Cafe' started by Danomo, Feb 10, 2015.
  1. Danomo
    Danomo Tele-Holic
    Chicago
  2. Gautfrid
    Gautfrid Banned
    England
    An almost invisible repair...
  3. idjster
    idjster VERY grateful member Silver Supporter
    Saskatchewan, Canada
    Good $49 body and electrics. Not such a great neck, but a deal at $49. You're going to change out the pups anyway, aren't you? Just don't go to the same tech as did the neck repair!
  4. Mellencaster
    Mellencaster Friend of Leo's Silver Supporter
    North Bay Ont. Canada
    Great deal for $ 49 but when did they start making s'mores glue :lol:
  5. src9000
    src9000 Poster Extraordinaire
    Albrightsville, PA
    It'll buff out.
  6. christhee68
    christhee68 Friend of Leo's
    south carolina
    It's purely cosmetic. The crack doesn't go all the way through. It's just in the finish. Stays in tune perfectly. Plays like butter.
  7. allen082
    allen082 Friend of Leo's
    fort worth
    Who uses spray foam to fix a guitar neck?
  8. Kennedycaster
    Kennedycaster Tele-Afflicted
    Mesa, AZ
    Now would be a good time for a little friendly advice about wood repair.......
    NEVER USE GORILLA GLUE ON ANYTHING.......EVER!
    Titebond is the way to go. What would have been a pretty straight forward repair will now be a time consuming nightmare. All the old glue must be removed & Gorilla glue swells the wood grain, so even after it's cleaned off, the two pieces won't fit together properly.
    That being said, I'd pay $49 for that mess. You could make a few bucks in parts anyway.....
    Bob
  9. jipp
    jipp Friend of Leo's
    apache junction az
    heh worse choice for glue for many reasons.. one is it adds water to the joint before it even expands.. hhe.
    chris.
  10. muchxs
    muchxs Doctor of Teleocity
    New England
    I've seen a few Asian Lesters with busted necks. Seems to be a 50/50 split pardon the pun between headstock breaks and neck joint breaks.
    We have two horizontal mortisers in our workshop. When it's not so cold out there I'm going to make a Les Paul jig for the mortiser.
    It's a relatively intrusive process to clean out the neck pocket but it's like new when it's done. Only difficulty is finding a replacement neck...
    Which brings us to another back burner project: Converting bolt on necks to long tenon set necks. Not as difficult as it seems! Done right it's stronger than the original Asian neck. Drop one of those on the floor. It will break the floor.
    I engineered a modified set neck that's almost as strong as a neck- through.
    It all evolved from a simple concept: I don't like bound fingerboards with big inlays. Unbound rosewood is o.k. and I prefer dots.
