Chorus pedal with adjustable mix control by foot?
Discussion in 'The Stomp Box' started by udoering, Jul 14, 2016.
  1. udoering
    udoering Friend of Leo's
    near Cologne, Germany
    I am looking for chorus pedal (which might be combined with a delay or another effect in one box) that allows to control the intensity of the effect (or wet / dry mix or whatever you want to call it) by an expression pedal. The only device I found is the Boomerang E-155, which costs a considerable amount of money. Are there other pedals in the market with this feature? Do you have personal experience with them?
  2. Lies&Distortion
    Lies&Distortion Tele-Afflicted
    SE Michigan
    My Neunaber Wet will. It's a reverb pedal with a jack to assign an expression pedal to any of the controls.
    You can program it to be a chorus pedal.
  3. DaveKS
    DaveKS Friend of Leo's Ad Free Member
    KS
    Get one of these instead, then any pedal or even a chain of pedals has a foot controlled mix control. You can line up chorus>delay>reverb pedals and any one of them or all of them can be foot blendable as you desire depending on which you turn on. Much better option than depending on a one certain pedal maker you happen to like adding a external blend control. You can even use it to blend distortions if you want. Having the blender seperate, your miles ahead in the race.
  4. EddieLocrian
    EddieLocrian Tele-Afflicted
    Isle-of-Wight
    Mad Professor electric blue chorus.
    This has a 0~100% blend.
    Put a 2 inch rubber grommet on the blend knob, you can twist it with your sole.
    OK - Eddie.
  5. jddub440
    jddub440 Tele-Holic
    Tacoma
    The EHX Good Vibes is a chorus & vibrato with an expression jack that can adjust the speed or the intensity; whichever you desire. I don't have any personal experience with the Good Vibes but I have lots of experience with other EHX products and so far they've never let me down.
    Moog also makes a MF Chorus which can have the rate controlled by the expression pedal....all they're MF series has expression capabilies; even the overdrive and boost pedals!
    I have absolutely no experience with any Moog products however.
  6. waparker4
    Philadelphia, PA
    Xotic X-blender
  7. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    The grommet idea is excellent. That opens it up for lots of chorizo pedals, like the Corona:
    FX Level is the wet/dry mix.
  8. waparker4
    Philadelphia, PA
    What's a chorizo pedal? Sounds yummy!
  9. BigDaddyLH
    That was on purpose, I swear! Chorus pedals get such a bad rap, I think we need to rebrand them.
    waparker4 likes this.
  10. robert donithan2
    robert donithan2 Tele-Holic
    Baltimore Maryland
    A DigiTech rp90 or higher multi-effects pedal... I think they're $99 new....
  11. blowery
    blowery Tele-Meister
    CO
    Source Audio One Series pedal. You can get the Gemini chorus, has a mix knob on it or you can use an expression pedal. There are also a bunch of other presets/usage phasers etc you can assign to this pedal.
    With the app you can do a ton of stuff, add tremolo, phaser etc. You get 3 factory presets, and in the other mode another 3 presets you can add the above stuff. Great pedals.
  12. udoering
    Thank you all very much for your inputs. The grommet idea maybe cheap and easy, but as I know my skills to keep balance, it won´t work with me. In the meantime I also thought about a digital multieffect-device with built-in pedal, which would be the cheapest solution; the question will be: how good is the sound quality of the effect? The Mosquito Blender sounds like a good idea, as it is not limited to one effect. The Neunaber also sounds interesting. I think I will have to investigate more on the various options.
  13. Lies&Distortion
    SE Michigan
    I have to ask, would you be changing the mix or intensity of your chorus pedal often enough to make a 2nd & possibly 3rd pedal necessary?
    Seems like a lot of work for the task. I like the big knob idea best.
  14. udoering
    As a regular attendant of the TDPRI Weekly challenge over at Twangers Central, I often record guitar tracks. One effect I relatively often use in Cubase is to put a vibrato in an effect channel, getting it´s input from the guitar track. If you then mix in the effect channel, you get a beautiful sounding chorus effect, and changing it´s intensity by in- or decreasing the effect channel´s volume is something I have learned to love. So that´s the reason why I would like to have the same functionality with my stompboxes.
  15. mabley123
    mabley123 Friend of Leo's
    ashland kentucky
    MOOG Clusterflux
    This baby is all analog, has 5 expression pedal capability. Its not cheap.
  16. Lies&Distortion
    SE Michigan
    I see, sounds like you have a plan! Carry
    on...
  17. Lies&Distortion
    SE Michigan
  18. mabley123
    ashland kentucky
    Yep. If you could pull it off.
    You could have 2 EXP pedals under 1 foot, and 3 under the other, while sitting down.
    But yes. You can use all 5 functions at the same time. I haven't done it.
  19. richey88
    richey88 Friend of Leo's
    philly suburbs
    Kickdisk. Saw it on YouTube . Unwieldy perhaps but looks like it will do what you're asking. Just got a Donner Harmony chorus, has a mix knob. Great pedal!
  20. udoering
    I definitely would like to say thanks to everybody who gave an input here. Some of your proposals or ideas I would have never found by myself, and that is surely one of the benefits of this forum: that there are so many players who are willing to share their knowledge and experiences with others!
