Choke wire colors
Discussion in 'Shock Brother's DIY Amps' started by Tom Kamphuys, Jul 19, 2020.
  1. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    My choke (Hammond 194F) has a black and a red wire. In my theoretical world it wouldn't matter whether it was connected one way or the other to the circuit. Is there a practical reason why they would give the wires different colors? Am I missing something?
  2. Kevin Wolfe
    Kevin Wolfe Tele-Meister
    Lakeland FL
    My vintage Blackface Fender has 2 black wires. Not sure why it would matter, but what do I know?
  3. King Fan
    Salt Lake City
    My ClassicTone choke had two black wires. Classic, for sure. :)
    I agree with your guess, Tom, they're equivalent, but I await enlightenment from the wise ones...
    Kevin Wolfe and sds1 like this.
  4. koolaide
    koolaide Tele-Afflicted
    south carolina
    Only a guess- Much like Leo fender, they had or got some red wire cheap or were running low on black..... Others with more knowledge will hopefully provide other applicable answers.
    Kevin Wolfe likes this.
  5. dogmeat
    dogmeat Friend of Leo's
    Alaska
    maybe test it. hook up to a headset and put it next the your power transformer. distance and orientation matter. I'd set it in a spot that makes a noticeable hum, then switch leads
    I've used headphones to find optimum positions for choke & output trannys, funny I never thought to switch leads. kinda doubt it will matter but who knows. now I gotta try that
  6. dan40
    dan40 Friend of Leo's
    Richmond Va
    Either wire will work. Can't say why they would use two different colors but I like koolaides theory. It's just one long wire coiled up around a bobbin, with a hookup wire on each end to connect it into the circuit. You can use it in either direction with the same results.
    King Fan and sds1 like this.
  7. Lowerleftcoast
    california
    There is a *start* and *finish* to any winding. IDK if it makes a difference with a choke. I do like the proposal from @dogmeat to check it out.
    Hey, the inner and outer make an audible difference with capacitors so maybe.
    Kevin Wolfe and dogmeat like this.
  8. dogmeat
    Alaska
    so.... I put a small Fender choke next to an 18 watt Classic Tones power tranny and couldn't tell any difference by listening. I hooked up the O-scope and there was no appreciable difference in induced voltage when switching leads.
  9. screefer
    screefer Tele-Holic Silver Supporter
    kildonan
    This is very edifying for rookies like me.
    Thanks for the effort!
    dogmeat likes this.
  10. dogmeat
    Alaska
    ya well... it's one of those things you don't think about but when somebody does... ya just gotta find out, so thanks all, now I know too!
    dan40 and screefer like this.
