Cherry wood
Discussion in 'Tele Home Depot' started by mangus, Nov 9, 2019.
  1. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    Cherry is great wood to work with the one thing to watch out for is the light sap wood it won't darken in time like the rest of the wood. it's best IMO to just use clear on it you will be surprised how dark the wood gets.
    Macrogats, OldDude2, brandonh and 6 others like this.
  2. 6stringcowboy
    6stringcowboy Friend of Leo's
    Central North Carolina
  3. guitarbuilder
    Martin made some cherry necks a few years back as part of their sustainable line.
    Mr_Q and crazydave911 like this.
  4. telepraise
    telepraise Tele-Afflicted
    Tampa Bay
    I'm not sure which species of cherry you get over in that part of the world, but the cherry that grows here in the states is definitely softer and lighter than rock maple. A neck should be OK with a good truss rod. As a fingerboard material, it's really pretty soft and will wear faster unless you impregnate it with super glue or epoxy. As mentioned by SacDAve, cherry is mauve to pink in color when first milled but darkens to a rich red over time with exposure to light. It sounds like you got an amazing deal on about 75 board feet. I would imagine cherry runs $4-6 bd ft here in 4/4 thickness. Post picks when you open the slab up.
    crazydave911 likes this.
  5. bsman
    bsman Friend of Leo's
    Santa Clara
    I had a Martin SWOMGT (cherry B&S) that I stupidly sold off. It was a very good sounding guitar.
  6. rangercaster
    Knoxville TN for now
    Cherry is excellent ... I like mine covered with chocolate ...
    OldDude2, eallen and bsman like this.
  7. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    Yes , you should have kept it . Their OM in cherry was rather sweet .
    Sweet cherry/ringbark and sour cherry trees/wild or black will typically produce different grain and degree of redness over time with wild cherry tending to have more visual appeal to the grain and tending to become more red with UV exposure .
    Quartersawn preferred for necks .
    bsman and crazydave911 like this.
  8. Beatbx
    Beatbx Tele-Meister
    Eugene, OR
    I like cherry for tops. It’s hardness is comparable to red maple which makes great tops imo. I would bleach it before putting finish on as it will darken over time.
  9. Gipper
    Gipper Tele-Meister
    Belleville, Illinois
    This body is cherry and maple. Accent stripe is mahogany.
  10. RolandG
    RolandG Tele-Meister
    I’m guessing that’s because there are fewer cherry trees than maple/alder/ash, and they don’t grow as large.
    OldDude2 likes this.
  11. mangus
    mangus Tele-Meister
    Portugal
    Thanks for all the answers
  12. epizootics
    epizootics Tele-Meister
    Lyon, France
    I have never worked with American cherry (Prunus Serotina) but I have used a lot with its European counterpart (Prunus Avium), mostly for furniture making. My understanding is that the Avium species yields slightly harder wood, but I've seen a lot of variation in hardness from one board to the other. It's one of my favorites to use in the workshop because of how easy it is to work with hand tools. Plus it smells great, like I've been cooking a cherry pie instead of making a bunch of sawdust.
    It is strong enough to make bodies and necks. Cherry is famous over here for how much finish it soaks up, even fast-drying ones like shellac. It just drinks it up, so I always make sure I saturate it before I apply any other more expensive / slower drying finish on top. I guess epoxy resin would work well there too, and harden the surface a good bit.
    Make sure you plane your blanks oversize, let them adjust for a while and thickness them to their final size once the moisture & internal stresses are gone. Cherry and walnut both suffer from being seen as 'furniture wood' but they both make great guitars and people love to work'em.
    crazydave911 and Rock-Ola like this.
  13. DrASATele
    North of Boston
    Oh, that sounds like an awesome block of wood. I would make tops and backs out of it. Tops about @ 1/4 to 1/2 inch bookmatched over a hollowed out body blank is awesome and weight friendly. I find solid guitars from cherry on the moderate side in weight so I lean towards hollowing.
    Scraps are great for smoking ribs, brisket, chicken . . .
    but oh yeah, cherry is awesome
  14. Vizcaster
    Glen Head, NY
    The few projects I've done with cherry have run into two issues that can easily be dealt with. First, if you hesitate with the feed speed on a router, the cherry will burn and you'll need to sand out the dark brown marks. Second, staining is a challenge because dye stain will absorb unevenly and look splotchy. An application of boiled linseed oil before staining or sealing will deepen the color and bring out any figure. It benefits from a washcoat of thin finish (a conditioner coat) before staining, if you decide to stain it at all.
    I haven't experienced much wood movement when dimensioning cherry, but that could be just luck of the inexperienced. Id be careful to leave some extra when resawing the thick lumber into usable boards.
  15. mangus
    mangus Tele-Meister
    Portugal
    So should I run the router faster?
  16. dougstrum
    dougstrum Friend of Leo's
    blu ridge mtn cabin
    It's not the speed of the router, but lingering to long in one spot that cause darker burn marks.
    Keep the router moving and you will be fine~at worst you'll have to do some extra sanding.
    mangus likes this.
  17. Jim_in_PA
    Jim_in_PA Friend of Leo's Silver Supporter
    SE PA near New Hope PA
    Don't you know it's extremely sinful to dye or stain cherry? :D :D :D
  18. epizootics
    Lyon, France
    Yup, staining cherry can be a dangerous exercise. As pointed above, it darkens quite a bit with time, both from UV exposure and oxidation, so you might end up with an unexpected results down the line. UV inhibitors in the topcoat will help slow down the process, but won't eliminate it.
    All of the Prunus species I have worked with exhibit that characteristic. My apricot solid body from three years ago has already darkened a a lot, in a nice way. Talking of the genus, I always try to get quarter sawn lumber if I can, they all exhibit some very nice ray flakes when QS.
  19. GearHund
    GearHund Tele-Holic Gold Supporter
    East, Tx
    Macrogats, RiversQC and LeftFinger like this.
  20. billder
    billder TDPRI Member
    Winnipeg
    Here are some work in progress pics from a recent build of twin Strats. The cherry was noticeably more stubborn to cut out with a jigsaw than the maple. You can see the oxidization between the top & arm cut. I "stained" with aniline dyes anyways, so darkening afterwards wasn't an issue. Water base lacquered & sanded to about 2000 grit in the bottom photo I think (not polished yet).
    Good Luck!
