I have no oscilloscope, and don't really care to have one; but I'd like to find a more definitive way to determine which lead is connected to the outer end of film-foil (and metallized foil) "non-polar" caps. I've tried the blunt instrument (cable) approach using alligator clips connected to a bare jack that's inserted over the instrument-end plug of a cable inserted into an amp; and I can't tell a difference convincingly between a cap going one way and then the other -- partly because when I disconnect the cap, there's a ton of loud hum (don't want to infuriate my neighbors), which obliterates my memory of the previous test when compared with the next one with cap reversed. I'd like a relatively instantaneous switch between one cap orientation and the other, and silence between them, with volume on the amp left untouched.
It seems to me: I need a reliable method of shorting out tip and sleeve of the instrument cable continuously in the interval between cap oriented one way, and cap oriented the other way. And that the answer might be a double pole "make before break" (aka "shorting") switch that will swap the connection of tip and sleeve to cap. I can't seem to find such an animal. What I do have on hand: a double-pole on-on-on slide switch, like this one:
Trouble is, it isn't "make before break" -- switch is open between positions. The thought occurred: get a momentary-contact push-button or toggle that I could actuate, to short tip and sleeve while flipping the other switch to reverse polarity (without unclipping the cap from the 'gator clips). Does that sound reasonable? Or does anyone know of a DPDT shorting switch that is reasonably priced?
