Check my Battery with my multi meter?
Discussion in 'Bad Dog Cafe' started by OlRedNeckHippy, Oct 19, 2020.
  1. OlRedNeckHippy
    OlRedNeckHippy Friend of Leo's
    South Jersey (Atco)
    Can I Check this Battery with this multi meter?
    If so, how ?
    The charger is on it in the pic.
  2. stormin1155
    stormin1155 Tele-Holic
    Iowa
    Sure you can! Set it for DC V 20.
    Tonetele and OlRedNeckHippy like this.
  3. Torren61
    Torren61 Poster Extraordinaire Gold Supporter
    CA
    Well, your multi meter is going to show what's in the battery at that moment and not under load. So you can get a good voltage reading but that might change when it's trying to do work. I don't know how you'd test for that with a multi meter.
    OlRedNeckHippy likes this.
  4. Dano-caster
    Dano-caster Tele-Meister
    Snore'n desert
    If you are having a problem with that battery, this is the test.Throw it up in the air and if it comes back down get a new one.
  5. DougM
    DougM Poster Extraordinaire
    Honolulu, HI
    Testing a battery with a meter will only tell you if it has any voltage, but it could still have no current capability. This is like the old drugstore tube testers, which would tell you if a tube was alive or dead, but not if it was functioning properly.
  6. MarkieMark
    MarkieMark Friend of Leo's
    Eastern USA
    As others have stated, yes you could test the existing voltage of the battery with that, but that would give limited info.
    IE: it could show voltage in an acceptable range but still be bad.
    To start with, what we are missing here is a symptom.
    Next, what is the chemistry of said battery? The only clue is the charger, which shows multi-chemistry capability.
    In my experience, if it is ni-cad, has some age on it and doesnt seem to "hold a charge"
    Stop wasting your time. Toss it in the recyclers bin and dont look back. Save you multi-meter for fun things like evaluating guitar pickups.
    And actually, no matter the chemistry, if its not performing as expected, its probably done.
    And just as well, if its ni-cad, dont even invest in replacement. You need a cordless tool upgrade.
    But fyi, the proper test regardless, would be to monitor the voltage under a nominal load appropriate for the battery capacity and to track the voltage over time.
    All results of this test, regardless of battery chemistry will degrade over time and number of charge cycles, with some chemistrys performing far longer and better than others. And with ni-cad at the bottom of the performance scale for modern designs.
    Next question please...
  7. OlRedNeckHippy
    South Jersey (Atco)
    Thanks guys.
  8. joe_cpwe
    joe_cpwe Tele-Holic
    WI, USA
    Multimeter....tongue....plenty of ways to check a 9 volt battery
    Boil likes this.
  9. Obsessed
    Obsessed Telefied Silver Supporter
    Montana
    Actually, you can measure the volts DC from your 20 V setting and then charge the battery and test it again to see if it is charging very well. It won't show you much more, but it will eliminate the charger or the battery as major issues. Consider it the first step in troubleshooting.
    DougM likes this.
