Cheap Pedal Mods For A Beginner....
Discussion in 'Burnt Fingers DIY Effects' started by hymiepab, Mar 10, 2016.
  1. hymiepab
    hymiepab Tele-Meister
    Hartford CT
    I've looked at Brian Wampler's book on modding pedals and am interested in destructing/improving some inexpensive effects boxes. A good amount of the pedals in Brian's book have gotten a bit on the expensive side in 2015.
    Do any of you have any ideas for cool mods I might start with, say for around $50 total ?
    I have a CS-3 and Bad Monkey, but at this point, there are things I really like about both of them, so I'm looking to start with something I'm not yet attached to!
  2. waparker4
    Philadelphia, PA
    Boss SD-1 or Boss DS-1.
  3. ranjam
    ranjam Tele-Holic
    Buy a used DS-1, and tweak the clipping diodes. Then tweak the tone controls. Total cost should be way under $50. Or buy a used NYC Muff and flatten the mids with one capacitor change. Should still be under $50.
    dronester1 likes this.
  4. whiteop
    whiteop Tele-Afflicted
    SD-1 Fallclone mod. Def worth it
  5. 6stringcowboy
    6stringcowboy Friend of Leo's
    Central North Carolina
    http://www.monteallums.com/ has some great mods for many different pedals. I've heard that his CS-3 mods are likely the best available. Also WELL within your budget.
    earsfull likes this.
  6. Tony Done
    Tony Done Friend of Leo's
    Toowoomba, Australia
    Switchable symmetric clipping mod on SD-1. Very easy, and it gives a nice choice in OD sounds. I happen to prefer the asymmetric mode, but if you like TS-type OD, the symmetric mode is OK.
  7. Iago
    Iago Friend of Leo's
    Brazil
    I'd agree that the SD-1 is almost inexpensive and serves as a great platform for mods. The DOD OD250 & the MXR Dist + also have their own collection of mods, mostly involving diodes, I think.
  8. Mountianjustice
    Mountianjustice Tele-Meister
    SouthCentral Pennsylvania
    Wah pedals are also a great modding platform. Voicing options sweep options you could build a fuzz right into the enclosure. Mod the wah to be a volume pedal and have a fuzz that cleans up as you rock the pedal with or without the wah effect. They are cheap and very easy to work on.
  9. Cain61
    Cain61 TDPRI Member
    Joseph, Ore.
    I've been thinking of doing that. I just had a snarling dogs blue balls wah go completely kaput as far as the overdrive and three-position wah. It still conducts through to the next peal though. Any ideas?
  10. Iago
    Brazil
    The problem is some component on the PCB, or maybe a loose wire. Probably not the footswitch.
  11. hymiepab
    Hartford CT
    Thanks for the ideas....time to get looking!
  12. dronester1
    dronester1 TDPRI Member
    Corpus Christi, Texas
    Thanks vicariously for the info, gentlemen!!
