Cheap-and-dirty expression pedal build.
Discussion in 'Burnt Fingers DIY Effects' started by Rich_S, Feb 23, 2020.
  1. Rich_S
    Rich_S Friend of Leo's Silver Supporter
    Potsdam, NY
    I wanted to add an expression pedal to my EHX Grand Canyon delay, so I can vary the wet/dry mix and regen on the fly, or do volume swells into long delays. So, I re-painted and re-purposed an old Cry Baby shell that I've had lying around for ages.
    Wile I was at it, I added a mini-toggle to switch modes. In VOLUME mode, it's just a simple passive volume pedal. In EXPRESSION mode, the input jack accepts a stereo TRS plug that mates up to the Grand Canyon's EXP input.
    Works great. Total cost: $0.00
    stevemc likes this.
  2. tah1962
    tah1962 Tele-Afflicted
    Heart of Illinois
    Nice.
  3. kennl
    kennl Tele-Afflicted
    Moon Township, PA
    Can you provide the wiring layout you used? SPST or DPDT switch?
    I built one for my Line 6 DL-4 and would like the volume pedal option.
  4. Rich_S
    Potsdam, NY
    I used a DPDT. I’ll draw up a schematic tomorrow and post it.
  5. Rich_S
    Potsdam, NY
    As promised.
    In Expression mode, the output jack does nothing and the input jack accepts a TRS stereo plug. The Grand Canyon sources 5 VDC on the ring and accepts a 0-5 VDC CV signal on the tip. I assume other CV-controlled pedals are the same.
    I used the Cry Baby's existing pot, which is around 125 Kohms. That's bit low for a volume pedal but it works okay, especially if you have buffers around it. I usually have a few Boss pedals in any effects setup, so I'm good there. Without buffers, the low pot value might cause some tone suck, but you can compensate with more gain and/or treble on the amp. Since the volume pedal doesn't have a bypass switch, the tone suck is "always on" and a tweak of the amp's controls should take care of it.
    Mouth likes this.
