Charvel Inspired Strat or Strat Inspired Charvel?
Fatcat211
Nyc
I’m surprised you didn’t trim away the headstock side of the fretboard before gluing it down to make room for the locking nut. Is it because you might need some to bring it to the proper height?
Captain Nutslot
Rochester, NY
This was scary. I snuck up on it and avoided routing to far into the head side of the existing nut slot.
I evened out the remainder with a sharp chisel and sanding block.
thumbs up ;) I have some finessing to do especially with the transition.
the bottom of the string slots are 1/16” above the fretboard currently. That is what I measured from a Jackson I have with the same kind of Floyd Rose.
This will work for now. Moving on...
Blue Bill
Noooooooo! Don't give up on the stainless! There must be a way, it's been done lots of times.
Nice job on the nut-slot adventure!
(Edit) OK, easy for me to say. I looked around, looks like it takes either a $100 set of cutters, or a diamond grinding blade for a Dremel. I wish I had better news.
Funny, I've heard people talk about S/S frets as if they're not much different to work with than regular ones. Go figure.
Captain Nutslot
Rochester, NY
they are tougher than I imagined!
I have these. They work great.
https://www.jescarguitar.com/shop/summit-straight-overhang-fret-end-cutter/
If you want to drive to Brighton you can borrow them.
much appreciated! But I think I’ll just Smack in the nickel silvers the way I always do.
