JohnnyThul
Hi all,
I am currently in the process of finishing another guitar and now encounter a problem with the Bigsby I was going to use.
In fact I have 2 Bigsby B-12's, I guess, both are from the 90's. I wanted to change the rollers for Callaham ones. On one Bigsby, I tried to pull out the pins which hold the ballends, but 2 just snapped of unfortunately close to the roller.
I couldn't extract them with the tools I had so I tried to gently force the roller through the needle bearing -> big mistake and I really could kick myself for not thinking and being in a hurry....well, the needle bearing broke.
However, I managed to find a replacement needle bearing (original Bigsby part), but how can I get the old one out? I assume, it's a press fit and I would need a puller, but I haven't seen one for such a small bearing.
Any suggestions?
BTW, I then tried the 2nd B-12 and the pins and rollers came out perfectly, no damage, but to my great surprise the Callaham roller won't fit one of the needle bearings, whereas the old roller does, how is that even possible??
I mean, the Callaham roller goes through one needle bearing, but not the other. I cleaned and checked the needle bearing, greased it, but it won't fit, I am completely clueless now.
Maybe I will just have to sand off the one side of the Callaham roller to make it work..
Unfortunately I am not set up for metal work, only wood, so, please keep that in mind
Best regards
Jonas
Any suggestions?
Best regards
Jonas
