Changing bent steel saddles on American Standards
Discussion in 'Tele-Technical' started by JohnK24, Oct 12, 2014.
  1. JohnK24
    JohnK24 Friend of Leo's
    Western PA
  2. Bigsnaketex
    Bigsnaketex Tele-Meister
    South Mississippi
    you are correct - replace as you desire.
  3. nosuch
    nosuch Friend of Leo's
    Cologne
    I don't think these will fit as the adjustment screw is off-center. I think you can get third party replacement saddles though.
  4. chezdeluxe
    chezdeluxe Poster Extraordinaire
    Brisbane Australia
    Incorrect!!!.Bigsnaketex
    Those (pre 2008) saddle mounting screws are offset from the saddle centre and thus the string through holes in the body. They will skew the strings to one side if you use them on a post 2008 American standard bridge.
  5. gentlyweeping
    gentlyweeping Tele-Meister
    Mpls/St. Paul, MN
    You are gonna' need the intonation screws centered on the saddles.
    Spacing is 2 & 1/16".
  6. Bigsnaketex
    South Mississippi
    Then they're incorrect on mine that I replaced them on. They lined up just fine even though the originals were offset.
  7. Rich_S
    Rich_S Friend of Leo's Gold Supporter
    Potsdam, NY
  8. chezdeluxe
    Brisbane Australia
    I guess the string tension must pull the saddles around so they are not sitting at right angles to the rear of the bridge plate.
  9. 1300 E Valencia
    Fullerton CA
    The new stamped saddles sound better (yes... yes they do), so why would you change them? Merely for looks?
  10. chezdeluxe
    Brisbane Australia
    Yes for what it's worth I have no problem with any aspect of the bent steel saddles on my 2008 American Standard.
  11. brenn
    brenn Tele-Afflicted
    Kentucky
    Keep in mind, there are 2 styles of the block style saddles - the ones you linked have the screw offset to one side of the body and they will only work on a bridge drilled for saddles with an offset intonation screw. Yopu can get others that use a screw in the center and will replace saddles with a screw in the center.
    If what you mean by "bent steel saddles" is Fender vintage style saddles like these, you will need to replace them with saddles that have the attachment/intonation screw in the center - NOT the ones you linked to.
  12. chezdeluxe
    Brisbane Australia
    Is there some sort of echo in this thread.? :confused:
  13. dhuber
    dhuber Tele-Meister
    Wyoming
    I just bought a 2014 American Standard HH. I own other Strat's and Tele's that have the block saddles. I was going to change out the stamped saddles on this new Tele because there is no groove in the saddle to keep the string centered. In my mind if I'm bending a note the string is going to slide across the saddle. If it does not return to where is started the tuning on that string will be off. Someone correct me if I'm wrong. The whole purpose of a fixed bridge is tuning stability. I don't know how that can be achieved with a stamped saddle.
  14. Zender
    Zender Tele-Meister
    SC
    There are two mindsets on that.
    The string cam easily move on the smooth saddles reducing string stretching.
    The slotted saddles let the string sit in eactly the same place the whole time preventing the string from sitting in the wrong place which hurts tuning.
    6 of one mind. Half dozen of the other
  15. KevinB
    KevinB Doctor of Teleocity
    SC (S)lowcountry
    I have Teles with (three) plain saddles and Strats with plain bent steel saddles. Even when I bend notes the string tension keeps the strings from moving. I certainly have no tuning issues with them.
