Changing 4 Ohms Champ to 8 Ohms
Discussion in 'Shock Brother's DIY Amps' started by robtking, Oct 18, 2020 at 3:55 PM.
  1. robtking
    robtking TDPRI Member
    Dublin
    Hi All,
    I built a 5F1/2 a few months back and I'm really enjoying it, however, I now want to build a new cab to accommodate a 12" speaker as there's a lot more choice at 8 ohms.
    My output transformer has 4, 8 & 16 ohms secondary taps and my question is - should I install another 1/4 output jack and connect the 8 ohms secondary and jump the common ground tab back to the first 4 ohm jack? Do I need to be aware of anything else?
    Many thanks,
    Robert.
  2. glenlivet
    glenlivet Tele-Holic
    Marco.......Polo......
    yep, if your OT has an 8 ohm output, that's it. (if you want to keep the 4 ohm output)
    Lowerleftcoast likes this.
  3. robtking
    Dublin
    Perfect! Thank you very much. I thought I better ask first before making a mistake that could fry something!
  4. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    Just hook up the 8ohm tap where the 4 ohm was and tap off the 4ohm. You’ll probably Never use it again, lol.
    robtking likes this.
  5. sudogeek
    sudogeek Tele-Meister
    Palm Beach FL
    On most Fenders, the primary speaker jack is a shorting jack (like Switchcraft 12A) and the external speaker jack is non-shorting (like Switchcraft 11). Or, you can use your existing jack and wire a SPDT On-On switch to change the impedance depending on what speaker you connect.
    robtking and awasson like this.
  6. awasson
    awasson Poster Extraordinaire Gold Supporter
    Vancouver
    This isn’t a champ but it’s got 4, 8, 16 taps and I put a jack for each one. I’ve used all three since I built it so it’s well worth having the option.
    I like @sudogeek’s suggestion of a switch. I’d put in a 3-way rotary switch for all 3 taps.
  7. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    Are you using a negative feedback connection? You'd want to EITHER leave it as-is connected to the 4 ohm tap, OR (if you're getting rid of the 4 ohm option entirely) remember to use the correct resistor value with the new 8 ohm configuration.
    robtking, sudogeek and David Barnett like this.
  8. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Not if you want to connect each jack to different taps. If you decide you want to do your original scheme (4 ohm jack, 8 ohm jack), both need to be non shorting type. Just remember to never turn your amp on without a speaker plugged in.
  9. jmp81sc
    jmp81sc Tele-Meister
    Orange County
    I use a three way rotary switch in my builds, and use 4/8/16 ohm multitap ot, so I can plug in to different cabs easily.
  10. chas.wahl
    chas.wahl Tele-Meister
    NYC
    In case you're looking for a reasonably small (25 mm diameter) 3-position rotary switch marked "4 8 16" here's one. Schurter 0033.4032, rated at 10 A 250 VAC:
    https://www.mouser.com/ProductDetail/Schurter/00334032?qs=j1qng3XoT/nmBB89ILqcJQ==
    Not really cheap, though -- over $16 -- but multiple jacks add up too, and require more real estate. It has a "coin or screwdriver" slot rather than a knob. I think that Marshall may have used this, or something very like it.
    EDIT: it appears that AES sells the "Marshall" one ($27), somewhat larger, but with the same electrical rating
    https://www.tubesandmore.com/products/switch-rotary-impedance-selector-replacement-marshall
    and also the Schurter, or a clone of it ($13):
    https://www.tubesandmore.com/products/switch-rotary-impedance-selector-3-position
    AES also has a rotary switch with "pot-like" construction ($11), but with only 6A 125 V rating:
    https://www.tubesandmore.com/products/switch-rotary-1-pole-3-position
  11. robtking
    Dublin
    I'm checking for on/on switches now - thanks!
