Changes in weather
Discussion in 'Tele Home Depot' started by soonerdude, Sep 19, 2019.
  1. soonerdude
    soonerdude Tele-Meister
    Lexington, KY
    noticed this on a home build. Neck is slightly separated from body. Any thoughts on how to repair?
  2. D'tar
    D'tar Friend of Leo's
    WNY
    Remove/clean/refit and reglue. It appears to be a poor glue joint IMHO.
    soonerdude likes this.
  3. EsquireBoy
    EsquireBoy Tele-Meister
    Paris, France
    And before resetting the neck, just be sure to double check if the neck angle is right.
    magicfingers99 likes this.
  4. Freeman Keller
    Freeman Keller Tele-Afflicted
    Exactly what D'tar said. And get every bit of the old glue out of there before redoing it unless its HHG
  5. Despres
    Despres Tele-Holic
    Northeast again
    Meh, just put a neck plate and some screws on the back!
  6. magicfingers99
    magicfingers99 Friend of Leo's
    atlanta
    it does look like someone tried to put a setneck on a bolt on body, difficult to tell for sure in the pictures. If you can clean out the glue and bolt it on it would much easier to adjust the neck in the future.
    I have set neck guitars and bolt-ons, prefer the bolt-ons whenever possible. all set necks, will eventually need reset, unless they are carbon fiber or someother esoteric design.
  7. magicfingers99
    atlanta
    some appropriate music while you contemplate your course of action:
    weather with you...
  8. soonerdude
    Lexington, KY
    Definitely not a bolt on body. And that someone was me, but stayed solid for the past couple years until recently. Either way, the joint failed. Was my first and probably last set neck attempt.
  9. nvilletele
    nvilletele Friend of Leo's
    California
    As Bob Dylan said “A change in the weather is known to be extreme, but what’s the sense of changing horses in midstream?”
