Champion 600 speaker upgrade, 6'' or 8''?
Discussion in 'Amp Central Station' started by BoogerRooger, Jan 5, 2011.
  1. BoogerRooger
    BoogerRooger Poster Extraordinaire
    Suffolk Coast
    I'm thinking of doing some upgrades on my Champion 600.
    Is it worth the extra expense and work to fit an 8'' speaker into the existing cab, or would a better 6'' one do the job?
  2. fezz parka
    fezz parka ---------------------------
    Del Floria's Tailor Shop
    Anything would be better than the cheapass car stereo speaker that it comes with. I put in a 50's Utah from a Moviola that sounds killer. If you can find an old P6T Jensen on eBay that would kill as well.
  3. Jaybird
    Jaybird Tele-Meister
    California
    I agree with Fezz. I have had both in mine. A nice6" Alnico from an old phono, and currently an 8" old Jensen C-850 from the 60s. They both sound better that the stock speaker. A good 6 in this amp is not that much less than an 8. One reason I think is because the cabinet is rather small and acoustics are limited.
  4. fezz parka
    I'm a big fan of more real estate on the baffle. I don't think it's so much having a bigger cabinet(since it's an open back), it's the sounding board-like qualities of the bigger baffle. Of course to have a bigger baffle means bigger cab...:lol:
  5. BoogerRooger
    Suffolk Coast
    I like the portability and style of the cab. But I could also build a seperate cab to plug into, hmmm.....
  6. fezz parka
    I added an extra speaker out to mine just for that purpose!
  7. Jaybird
    California
    I agree to some extent on baffle size. However I strongly believe that a proper ratio of cabinet size and shape to the speaker is more important. Too large a cabinet for a speaker is not conducive to the best sound even if it gives you more baffle area. That's just me though.
  8. fezz parka
    Aww it's all just spitballin'. If it sounds good it is good. If it don't sound good, well, you know...:lol:
  9. Jaybird
    California
    You got that. After thinking about it for a few minutes, The larger baffle afforded the 6" speaker as to the diminished baffle area with an 8" speaker could be a reason that a well made 6" speaker is about the same as an 8" replacement. :)
    Check out my ptp type rebuild of the champ 600 in the amp owners section.
  10. fezz parka
    I will!
  11. bdgregory
    bdgregory Tele-Afflicted Silver Supporter
    Virginia
    I would replace the stock speaker with a plug compatible 6", but rather than spend the effort to cram an 8" in there, I would install a jack that's more accessible that the one buried inside. Then get a good 12" cab to sit it on top of for when you want more volume. It sounds pretty good driving a 12".
  12. Chutist
    Chutist Tele-Holic
    California
    I just replaced the Stock tubes in mine with a set of JJ's and that was a big improvement!
    Speaker is next, I'm thinking a Weber 6" at the moment....
  13. fezz parka
    Look in these for great 6" speakers:
  14. First Time Tele
    First Time Tele TDPRI Member
    Darlings Island NB
    I lifted the R19 in my 600 and the 6" stock speaker sounded awful:mad:. However I hooked it up to my Pathfinder 15r speaker and it sounds great lots of volume and nice breakup.:cool: I hooked up a dano cool cat drive pedal and it was crunchy and nasty with my mexi-tele!:twisted: I would like to leave the R19 lifted, so I am looking for an 8" speaker for mine!:p
