Champ Kit build, no sound
Discussion in 'Amp Tech Center' started by goforit, May 9, 2020.
  1. goforit
    goforit TDPRI Member
    Orlando
    I just finished up my first champ kit and have a problem. There is no sound. When i initially tested my build i got a loud ear piercing squeal, Which i read may be due to positive feedback and could be fixed by switching output transformer primaries. After switching them, the squeal went away but i have no sound. Some voltage readings i took are as follows:
    12ax7
    pin1: 161
    pin3: 1.3
    pin6: 161
    pin8: 1.2
    6v6
    pin2: 16
    pin5: 320
    pin6: 285
    5y3
    pin1: 330
    the B+ voltages read 330, 285, and 245
    i see a common problem is a missing ground between the 22kohm resistor connecting the 8uf filter caps and the 100k ohm resistors that lead to the 12ax7, but I do have voltage there. I know it could be a number of different things, where should i start?
  2. Peegoo
    Peegoo Friend of Leo's
    Wyoming panhandle
    1. Discharge all electrolytic caps.
    2. Take a good look at your electrolytics to make sure they're in the right way 'round.
    3. Red-ink all the wires on the schematic or layout diagram. This means to go wire by wire in the amp, look at each one, and then draw over it with the red pen on the layout to account for it being connected to the correct terminations.
    I do the red ink thing as I build. It has prevented goofs (I used to get 'em) over the last 10 or so amp builds I've done.
    ce24, Treehouse and Strebs like this.
  3. FenderLover
    Minnesota
    Check your output stage wiring. Pin 2 is a heater, so 16V is not right. Pin 5 is Grid1, so 320V is not right.
    For the 6V6 measure pins 3, 4, 8 (plate, G2, cathode).
  4. dan40
    dan40 Tele-Afflicted
    Richmond Va
    When you took your voltage measurements, did you hear a pop through the speaker whenever you touched your probe tip to the plate leads of each tube?
  5. goforit
    Orlando
    @FenderLover
    I'm sorry, I made a mistake on the PIN numbers of the 6v6.
    pin2 measures 0 (not 16)
    pin3 is 320
    pin4 280
    pin8 16v
  6. goforit
    Orlando
    @dan40 I made a little 4ohm dummy load out of leftover resistors I have lying around. so no actual speaker is connected.
  7. dan40
    Richmond Va
    The "pop" test is a great diagnostic tool to find out whether or not the amp is passing signal to the speaker. Starting at the power tube, work your way back through the circuit. If the plate of the 6v6 pops but the 12ax7 does not, you have just narrowed down the area of the circuit that is not working properly. If every stage produces a pop chances are the input jack is wired wrong.
    Treehouse and D'tar like this.
  8. goforit
    Orlando
    @dan40 Okay I will try it out. Thank you for your help!
  9. D'tar
    D'tar Friend of Leo's
    WNY
    Pictures of the input jacks and the pop test
  10. goforit
    Orlando
    Here are pictures of the input jack. I just tried the pop test and did not get popping anywhere throughout the amp. what does that indicate?
  11. dan40
    Richmond Va
    Could be an output jack wiring problem. Are you using one output jack like the original or did you go with two jacks as seen in some of the other Fender's? Some models such as the Deluxe have a main jack and an extension cabinet jack. Plugging into the ext jack only would yield no sound at all. Original Champs only have a single jack so this could not be the problem if you stayed true to the originals.
  12. goforit
    Orlando
    @dan40
    I only have one output jack. could it be something to do with the output transformer?
  13. D'tar
    WNY
    You removed the dummy load and have the speaker plugged in right? Your voltages suggest your tubes are conducting. A few more pictures would be good. Lets see the output jacks too.
    On your inputs make sure the 1M leg is not touching the shunt, it looks real close but may just be the photo.
    dan40 and muchxs like this.
  14. muchxs
    muchxs Doctor of Teleocity
    New England
    First thing I looked at was your input jacks. That's always going to be a quiet amp, as- is. It looks like your input goes to ground.
    Wire it up with one input and your 1 meg grid leak. You'll have sound if nothing else is wrong.
    Jlwctn and dan40 like this.
  15. goforit
    Orlando
    @muchxs so the input jacks are wired incorrectly?
    would you mind explaining how they are incorrect? I dont really understand. should the second input not be grounded through the preamp bus? thank you for your help
  16. goforit
    Orlando
    @D'tar here is a picture of the output jack. Thank you for your help
  17. D'tar
    WNY
    They are correct as long as they aren't making unwanted contact. The green arrow looks like the leg is close to shorting on the shunt. The red circle around the other shunt looks close to the first jacks ground ring. Maybe give it a little bend away from the other jack
  18. goforit
    Orlando
    @D'tar here is a better photo of the input jacks. do they look okay?
  19. D'tar
    WNY
    Yep.
    The pop may only appear as a scratching sound on the 6v6 plate or grid. Should be more noticeable on the grids of the 12ax. Once you are operational ypu may want to shorten some wires up.
  20. D'tar
    WNY
    Make sure the unused output tap is not grounded.
    dan40 likes this.
