Champ 600 Owners Club
Discussion in 'Amp Owners Clubs' started by cjburr, Jun 13, 2009.
  1. bluesky636
    bluesky636 Tele-Holic
    Earth
    There is no need to overdrive the front end with a booster or other pedal. I can easily overdrive the power stage in my 5F1 configured C600 using just the pickups in my guitar. Power amp distortion is a completely different type of distortion and sounds totally different from preamp distortion.
    Subsequent stages do not "smooth" the signal whatever that means. If they are operated within their design parameters they will simply amplify the signal more. If they are not, they will also distort the signal.
  2. Lazer
    Lazer Tele-Meister
    Stockholm, Sweden
    A tube or a valve has a fairly limited frequenzy range and overdriven signals contains a lot
    of high frequenzy content. The closer to the output limit the harder it will get to follow
    the signal. This will have the effect of "rounding off" or "smoothething" the signal.
    Theorerically this is the same as filtering high frequenzy content. Just hook up an oscillosope an check for Yourself.
    "Subsequent stages do not "smooth" the signal whatever that means. If they are operated within their design parameters they will simply amplify the signal more. If they are not, they will also distort the signal. "
    The distortion You mention here is the "smoothing" i talk about and it work both ways.
    A clean signal will be "hardened" if You like, and an already distorted signal will appear
    "smothed".
    Yes preamp distortion sounds completely different, but unfortunately this is not the 600´s forte.
    Cheers
    L-zr
  3. bluesky636
    Earth
    I received my degree in electrical engineering in 1976, back when tubes were still part of the curriculum. When did you get yours?
    Just for grins and giggles, I tried your approach. I turned the amp down to about 5 and the guitar to 10. To get any kind of overdrive sound out of it (preamp or otherwise), I had to max out my E-H LPB-1. Even then the drive was barely audible. With the amp volume wide open and the guitar wide open I got great power tube overdrive with just the pickups alone. I know what I'll stick with. :cool:
  4. Bruce Wayne
    Bruce Wayne Tele-Holic
    Gotham City
    moved the heater wire off to the side a little while I was installing the new Weber Ceramic speaker today. reduced the hum a little bit. thanks Bill
  5. Lazer
    Lazer Tele-Meister
    Stockholm, Sweden
    "I received my degree in electrical engineering in 1976, back when tubes were still part of the curriculum. When did you get yours?
    Just for grins and giggles, I tried your approach. I turned the amp down to about 5 and the guitar to 10. To get any kind of overdrive sound out of it (preamp or otherwise), I had to max out my E-H LPB-1. Even then the drive was barely audible. With the amp volume wide open and the guitar wide open I got great power tube overdrive with just the pickups alone. I know what I'll stick with"
    A few years later... With everything wide open both of mine sound horrible so I know I'l
    stick with the sweet pot around 4-6 and overdrive the input.
    Cheers
    L-zr
  6. tlimbert65
    tlimbert65 Tele-Afflicted
    Northwest Iowa, USA
    Dang, that was supposed to say Squier Deluxe STRAT! That made no sense at all.
  7. bluesky636
    Earth
    Good to hear. :D
  8. bluesky636
    Earth
    That's cuz your's is stock and looks basically like this:
    http://ampwares.com/schematics/champ_aa764.pdf
    Mine looks like this:
    http://ampwares.com/schematics/champ_5f1.pdf
    BIG difference in gain structure and sound. :D
  9. Lazer
    Lazer Tele-Meister
    Stockholm, Sweden
    Close but not quite and then I don't see Your comparison making sense.
    My point is just that I like it best the way it is, and someone wants tons of distortion
    probably does better looking elsewhere.
    For me this unit is a sidekick that I don't see any point in spending too much on.
    That said I totally understand all the tinkerers out there that does it for fun. But
    my original post was for the rest of us.
    Cheers
    L-zr
  10. bluesky636
    Earth
    The comparison is simple and quite obvious: Fender in building the C600 made no attempt to replicate the sound of the amp as it was built in the late 40's/early 50's. Instead the design of the amp is a clone of the mid-60's Silverface Champ AA764 circuit. Totally different design, totally different sound. Compare the circuits. Except for the power supplies and a fixed tone stack, the C600 circuit is virtually identical to the AA764 right down to the component values.
    http://support.fender.com/schematics/guitar_amplifiers/Champion_600_schematic.pdf
    People that mod this amp are not looking for tons of distortion, at least I am not. Instead, people are looking for the sound of the early 50's Fender amps. That is easily accomplished with the removal and addition of a few simple parts. There is no need to change major components. Most people do change the tubes as the stock Chinese tubes are, quite frankly, crap. With those simple mods, the amp now appears as this:
    With the exception of a solid state power suppy, I have modded my amp to look exactly like the 5F1 circuit. The only other change I made was to replace the two 0.02 mfd coupling caps with two 0.0022 mfd coupling caps to raise the -3 db low end roll off from 7 hz up to about 70 hz to prevent muddiness when using the amp with a larger than stock speaker. I even changed the power supply resistors to the same values as the 5F1 which changes the tube supply voltages to more of what they were in the 50's (Fender supply voltages are way too high in the stock amp). Ignoring the cost of a speaker and tube change (which most people do anyway), the total cost of components for the mod is maybe $15.
    The net result is an amp that achieves probably 90% to 95% of the sound of a vintage Tweed Champ and gives a nice clean sound at low volume all the way to a sweet, cranked power tube overdrive at higher volume (but still at bedroom levels) with nothing more than a guitar plugged straight into the amp. Set the amp to 12 and control everything with the guitar volume control.
    I certainly understand that, I just wanted to explain why I and others find the amp so moddable. Rock on! :D
  11. Lazer
    Lazer Tele-Meister
    Stockholm, Sweden
    By all means go ahead and mod away. I am just trying to help the ones who doesn't
    want to. Find the sweet spot and use an overdrive pedal or booster.
    Some people on this forum do indeed want to transform this unit into a distortion
    monster.
    Cheers
    L-zr
  12. Kyluckyman
    Kyluckyman Tele-Holic
    Western Kentucky
    I am sitting here reading this thread while I wait very patiently for the Fed Ex truck to pull to a stop in front of my house and watch as the driver comes to the front door with my new Fender Champion 600 amp from Sweetwater. I will greet him at the door and accept the package. I have been eyeing this model since they were on sale during the holidaze 3 years ago for the awesome price of 89 bucks and free shipping. However I could not swing the purchase due to Christmas expenses and taxes on the house and regretted it since. So now, over three years later...I await delivery.
  13. MadJack
    MadJack Friend of Leo's
    ꓶꓞ ʻɹǝๅpuɐꓛ
  14. mrpicki
    mrpicki TDPRI Member
    I think these sound better at around half volume with good drive pedal, not a clean boost pedal but an overdrive pedal like a Tubescreamer. I've used mine in the studio this way with great results.
  15. bluesky636
    Earth
    That's cool, but you can easily mod the stock PCB to an exact 5F1 circuit (less the tube rectifier) and get the same results for a lot less money. Drop the voltage out of the solid state rectifier and the difference in sound between the two is minimal.
  16. asnarski
    asnarski TDPRI Member
    grand rapids
    Same here, I use a Bad Monkey at about half volume for distortion. Only mods are a decent 12ax7 and replaced the grill cloth. Sounds great to me!
  17. Amstrat
    Amstrat TDPRI Member
    Toronto Canada
    8" speaker query
    Greetings
    Read all 500 posts. Facinating.
    Want to yank my speaker and grill cloth and install an 8" on a new baffle.
    Points unsure of:
    Planning to use a Weber Sig 8"
    Q1 Regular or S? What is dif?
    Q2 Will is fit with a JJ 6V6s?
    Q3 Where do I source a small amount of speaker cloth?
    Q4 Best baffle board material.
    All the very best
    Larry
  18. Amstrat
    Toronto Canada
    oops missed one
    Q 5 What mounting hardware for nw speaker to new baffle?
    TIA
    Larry
  19. Mat
    Mat Tele-Meister
    Picked up my second last week (sold the original a couple of years ago).
    Really enjoying the stock sounds - came with a GT 6V6 and generic Chinese 12AX7 which sounded fine in conjuction with the stock speaker.
  20. Kyluckyman
    Western Kentucky
    I have ordered:
    GE JAN CG 6V6GT 6V6 GT
    and a
    Electro-Harmonix 12AX7 EH EH-12AX7
    We'll see how it goes.
