Wharfcreek
I recently acquired a Fender Champ 12, and just got around to 'testing' it today. The seller clearly misrepresented it, saying it was a perfectly good 'working as it should' amp with no problems. I took him at his word, paid him his $250, and went on my way. This was perhaps 3 to 4 months ago, and shame on me for taking so long to test it out. But, life got in the way as it often does, so here I am, and sadly things are NOT as represented. To begin, the speaker was blown. VC is locked up completely! So, I had an old 12" Celestion G12 here and into the amp it went. Presto!..... got good output and reasonable tone!!
Unfortunately, still has gremlins, as the overdrive LED is illuminated on the front and the hard-wired channel switch doesn't do a thing. I have no control with the main volume knob either, which is probably a function of the amp being in 'overdrive' mode. The 'Mid-boost' pull knob on the treble control does work, but 'reverb' is almost non-existent. With the control all the way down it's completely gone, and all the way up it's more like what you'd expect from a working amp when the control was somewhere between zero and 1. In other words, you can get a taste of reverb, but that's it!
So, just looking for suggestions here. For the record I did test the 3 tubes; one 6L6 and two 12AX7s. Tubes are fine! I have a nice tube tester from Hickok and I've been using it for years doing HiFi amp work. I'm OK with things like the output section, power supply, and you simple pre-amp sections. But, most of my amp work is all done on HiFi tube power amps, with very little done elsewhere. I do NO 'radio' or 'TV', and when it comes to solid-state stuff I RUN in the other direction. And, honestly, this 'channel switching' stuff and 'overdrive' it a bit out of my wheelhouse as well. So I humbly ask for some further advice here and hopefully someone with some knowledge of this amp and it's circuitry will point me in the right direction. By the way, there's a Schematic for this amp on Doug Hoffman's EL34 world, and I've looked it over to the best of my ability. I'm a little lost in following the signal path as it relates to the 'clean' and 'overdrive' parts. So, this will be a real 'learning experience' for me.
Thanks in advance for the help and consideration!!
Tom D.
Tom D.
