Chaining pedals in parallel
Discussion in 'The Stomp Box' started by Muzik4Machines, Nov 23, 2015.
  1. Muzik4Machines
    Muzik4Machines TDPRI Member
    quebec
    so i tried it with the LS2, but my 2 fuzz were now seeing the buffer out and it changed the sound a little
    Is there a passive way to do that (split the signal without loss and re combining it passively (or active, less of a problem at the output IMOHO)
    i want to gut my 2 chineese fuzz and put them both in a double size enclosure with the parallel stuff (and a series switch for good measure), both to save space on my pedal board and to have an all in one stoner machine (may even integrate my fake EP booster at the end after the summing)
    is there any way to do this or i am just dreaming of impossible things?
  2. bricksnbeatles
    bricksnbeatles Tele-Afflicted
    Long Island, NY
    Just use a non-buffered ABY box and then use a receiver box and yeah, should be good
  3. Muzik4Machines
    quebec
    but wouldn't the passive ABY load the pickup and alter the fuzz tones?
    and is the passive mixing of both ok to do?
  4. bricksnbeatles
    Long Island, NY
    Since its passive, it wouldn't do any more damage than an extra few feet of cable. As for the second question, I believe it's ok to do, I've done it many times before with no problems.
