Ceramic to Neodymium swap - Anyone tried this?
Discussion in 'Squier Tele Forum' started by guitar_paul1, Apr 23, 2021.
  1. guitar_paul1
    guitar_paul1 Tele-Meister
    washington state
    I had this idea and found a video on youtube of someone doing exactly this.
    Has anybody tried it?
    It seems easy to try and easy to reverse if needed. It sounds like it adds a bit of high end, but of course who knows?
    Has anyone tried this?
    I'll be reunited with my Squier affinity in a month or so. If I can pull it off, I'll post my results.
    That Cal Webway likes this.
  2. Fluddman
    Fluddman Tele-Holic
    Sydney, Australia
    So what would this actually change? Just the strength / density of the magnetic field?
    Are Neodymium stronger magnets?
  3. 5haun
    5haun TDPRI Member
    New Zealand
    Hmmm... I might try putting a small neodymium disc magnet on the bottom of each of the alnico3 pole pieces of my Fender "52 Vintage" reissue bridge pickup. It's hard to balance with the alnico5 "Cruel Mistress" neck pickup that I fitted. At least without moving the bridge p'up VERY close to the strings. I don't want to lower the neck p'up as the Cruel Mistress sounds best when it's set high (and it sounds VERY good).
    Food for thought, thanks. Of course getting a Cruel Mistress bridge pickup would solve the problem but I'm a bit short of money lately...
  4. stormin1155
    stormin1155 Tele-Holic
    Iowa
    I use dime sized neodymium magnets in my shop for various tasks. They are so strong that if you get your finger in the way of them snapping together they'll pinch ya good! I've used them to recharge weak magnets on pickups. I would be concerned that adding one to the base of an alnico pole would be so strong as to pull on the strings and dampen your sustain.
  5. guitar_paul1
    washington state
    I plan on using the small chiclet type magnets from discarded Sonicare toothbrush heads. I've made a 12 string lapsteel pickup from scratch using them and with a steel blade polepiece on the front side it measures about the same gauss as an alnico magnet right at the face near the strings.
    68Telebass likes this.
  6. 68Telebass
    68Telebass Friend of Leo's
    Northern Arizona
    That’s pretty cool!! Go for it!!
  7. edvard
    edvard Friend of Leo's
    Bremerton, WA
    I've asked this question before, and the response I got was that the steel pole pieces influence the sound more than the magnets do, and from a few videos I've see, the strength of the Neo magnets isn't that much more, and in some cases can be less, than the ceramic magnet it's replacing. I'd be interested in what pure iron slugs would sound like, and Neo on AlNiCo sounds intriguing, but probably not necessary, and may even be overkill. https://www.tdpri.com/threads/neodymium-pickups.1016824/
    I forgot the advice I received in that thread and recently replaced the ceramic-and-steel bits on my '03 Squier Strat with AlNiCo V magnets, and they still sound a bit high-strung, but better overall. I'd like to try some AlNiCo III magnets just to experiment. https://www.tdpri.com/threads/i-was...-the-heck-do-they-work.1066324/#post-10534294
    guitar_paul1 likes this.
