Cellulose without primer issues
Discussion in 'Finely Finished' started by Chordophonic, Jul 28, 2014.
  1. Chordophonic
    Chordophonic Tele-Meister
    Isle of Wight UK
    Im doing a ratrod style Strat, lefty body with right rout, right CBS neck, it's a new body made from Swamp ash, I will spray satin black cellulose rattle can, I want the paint to sink into the grain, will I have any major issues if I spray direct onto the bare wood, without primer?
    Paul
  2. CapnCrunch
    CapnCrunch Friend of Leo's
    Washington, USA
    Are you spraying Nitro cellulose lacquer? If you are, you should not have any problems. I would clean the wood with Naphtha and let it dry prior to spraying. You can also clean with alcohol, or acetone. You just want to make sure that all dust, and oil is removed prior to spraying. I've sprayed Nitro lacquer many times on bare wood with no primer or pre coat. I've also sprayed it over vinyl sealer and shellac. If you could seal with either of the above, you will use less lacquer. I seal when I can.
  3. Chordophonic
    Isle of Wight UK
    I am considering using satin Black rattle can cellulose car paint straight onto the bare wood....I will give it a go and see what happens, thats the joy of wood it will rub down and refinish if necessary!.....
  4. bluesplayer80
    bluesplayer80 TDPRI Member
    Just a suggestion, but Minwax makes a nitrocellulose-based sanding sealer (black can that says "Lacquer Sanding Sealer") that I've used and it's a great product- easy to apply... It would probably be a good idea to put a can or at least a few coats on before the color....
    Just a suggestion..
