Cedar for a neck
  • Thread starter g'ter guy
g'ter guy
Socal
anyone ever heard of using cedar for a neck? What about for a Fretboard?
mhainz
australia
Hmm. I'm no expert on wood but I'd think cedar would be too soft? Especially on a fretboard it'd wear out in no time.
RomanS
Vienna, Austria
Probably way too soft - I've got a Thinline with a cedar top on the body - it already dents when you look at it for too long...
zoppotrump
nuernberg, germany
i´m not 100% sure, but i think that talking to alan tomkins of Tomkins Guitars, he mentioned that he uses australian red cedar, which he described as much harder as regular cedar...., btw great sounding and playing guitars.....and he´s a really nice guy
jkingma
Super Moderator
Staff member
46.050888, -79.801023
I've seen acoustic guitars with cedar necks so there is no reason you can't make an electric guitar neck with cedar as well. Some cedars are a lot harder than others. But for a fretboard... forget it.
mhainz
australia
Pretty sure he uses Australian Red Cedar just for the bodies. Necks seem to be made of Queensland Rock Maple.
RocknDrTom
Lumberport, WV
The two lap steel on the right were both made out of solid cedar. I would not make a regular guitar neck out of this wood, but it's perfect for lap steel necks.
Telenator
Vendor Member
Vermont
You could use cedar if it's cut from the center of the tree where it's harder. Then you'd need to reinforce it internally with a hardwood core for the truss rod to sit in, and a perhaps thicker harwood finger board.
I would also suggest laminating the top and bottom of the peghead with hardwood.
Mojotron
Seattle
Spanish Cedar is a Mahogany.
When you mention Cedar - what species of wood are you thinking of? Cedar describes all kinds of very different woods.
MORCILLO
spain
Spanish cedar
Cedrela odorata
Is the aromatic wood of the cigar boxes, and it is not spanish, its from central america.
I heard interesting things about his tone in guitar making, and light weight too, but a neck... perhaps a more fat classical neck with nylon strings... well I have not the experience, but there are better woods for that.... I think.
jpbturbo
Banner Elk, NC
Spanish cedar
Cedrela odorata
http://kauerguitars.com/
makes bodies and necks out of spanish cedar and it seems to work fine.
Very similar to mahogany from the reviews.
ievans
Sucka Free, CA
Why is that? Mahogany is fine as a neck wood for electric guitars and steel-strings, and Cedrela odorata is a slightly lighter-weight wood in the mahogany family.
MORCILLO
spain
Well, they sell necks for classical, maybe it will be allright for steel too...
Al Watsky
New Jersey
I made 1 cedar neck for a SS electric solidbody.
It was a replacement neck. I built it out of curiosity.
Cedar with an ebony fretboard. Spanish Cedar. The aromatic type , not Mahogany. The type they make classical necks out of. Not the Red Cedar used to make tops. Its a different species for sure, but still not Mahogany as far as I can tell. If this stuff has anything to do with Mahogany wood taxonomy is even weirder than I thought.
It was very light and stable but it was very dark sounding in comparison to the neck it replaced.
In this case it was not especially desirable. It was on a Mahog body with a maple cap.
RomanS
Vienna, Austria
Guys we have to make a clear destinction:
"Spanish cedar" (cedrela) doesn't have anything at all to do with "real" cedar - it just got the name because it smells slightly similar... And as has been mentioned, it is closer to mahogany, and is used a lot, both as a body wood as well as for acoustic guitar necks.
So, using that for necks shouldn't be a problem at all.
"Real" cedar (actually, there are quite a few different kinds in that family - red cedar being a very common one) is a completely different story, it is a VERY soft wood, it is used for acoustic guitar tops, but I doubt that you could use it for a neck...
So, as long as we don't know what the OP has, it's hard to give advice, because we are talking about two completely unrelated and different kinds of wood that, unfortunately, share the same name!
