Cavalier Oildale
Discussion in 'Just Pickups' started by Rob DiStefano, Jul 8, 2019.
  1. DHart
    DHart Friend of Leo's
    Scottsdale, AZ USA
    Spec-wise (resistance), the Oildale and Fender Nocaster bridge pickups are very close. And both use A3 mags. You may not hear much, if any difference, between them.
    The Bakersfield has A5 mags, fewer turns, and a little lower resistance. The Bakersfield should sound a little bit sharper/brighter and sparkly in tone.
    If you play with a good bit of over-drive or distortion, you may not hear any difference between the three.
    That said, the Fender Nocaster is machine fed during winding (extremely consistent). The Cavaliers are human hand-fed during winding (scatter-wound, somewhat uneven). When playing clean, those who pay close attention to tone seem to notice the difference in tone with the scatter-wound. I think the scatter-wound pickups sound a little richer/more complex in tones/over-tones. You're not so likely to hear this, though, if you play with very much over-drive.
  2. revelation2012
    revelation2012 Tele-Meister
    Arizona
    Thanks. That's very helpful.
    DHart likes this.
  3. rigatele
    rigatele Tele-Afflicted
    Both machine and hand winding have two main factors that can influence the tone - wire tension and turns per layer. A higher tension and more turns per layer both increase the average proximity of adjacent wires in the coil. That, in turn, increases the coil capacitance, which decreases the treble response by lowering the resonant frequency. However, that difference is not very great. The coil capacitance is usually less than the guitar cord capacitance, and those interact. With the volume knob up all the way, the two actually just add. So this particular coil characteristic is a very minor contributor to the overall sound. Generally, tension and TPL are higher in a machine wind (but not necessarily so, as the machines can be adjusted for both). "Scatter wound" pickups generally have lower tension and TPL, usually by design - the whole point being to increase the treble. Also, the winder can vary the parameters. But the difference is only "with all other things being equal" and there are many other factors that play a much bigger role in shaping the tone.
  4. DHart
    Scottsdale, AZ USA
    rigatele... indeed. As I mentioned, some players may not even notice the subtle tonal difference between machine wound and scatter-wound. But if you play a very clean, clear style (especially solo - not in a band setting) there are tonal differences which may be heard and appreciated (and recorded).
    My appreciation for hand-fed scatter wound is in part for the potential increase in highs and an overall “richness and complexity” of tone.
    In a band setting and/or some EFX engaged (esp overdrive), these subtleties are less likely to be heard, if at all.
  5. rigatele
    Thing is, and I stress that it is not a quality measure but a question of "flavour", the capacitance of the Nashville that I measured was extremely high, 417pF. Compare with the NoCaster at 125pF. I have not had a chance to measure the Oildales, or any other Cavalier Tele pickup set. The Lion King was also quite high, at 390pF. This is no doubt a big part of the reason those pickups also have a quite low loaded resonant peak frequency. Rob would probably assert that it makes little difference but I find it quite interesting because it means that lots and lots of people actually prefer resonant tones that gravitate down in frequency from the typical 3kHz that you usually see on a Strat. This illustrates that low capacitance as a goal in itself will not benefit many people.
    Personally, I also play very clean and mostly into a DAW, and my musical style demands a clearer, more trebly and flat response, but without completely giving up the resonance provided by Alnico poles. That is why I have Cavalier Phoenix Firebird replicas on my main guitar. Those have a much higher response around 4kHz, even higher than a typical Strat. But the resonance is tamed somewhat by using 250k pots.
    ndcaster likes this.
  6. DHart
    Scottsdale, AZ USA
    I'm running my Cavalier Phoenix Firebird neck pickup (genuine article, but 4,200 turns vs. standard 4,500 turns) with an 880k Volume pot and a No-Load tone pot.
    I have no idea what the resonant peak is with this pickup, nor what the capacitance is. (I don't have the tools to take those measurements.) But going by my ears - I'm very much enjoying the tones with that set-up. Nice and sparkly bright.
  7. rigatele
    The standard Phoenix has a resonant peak of about +5dB and a capacitance of 185pF. Your peak will be higher because of the higher value pot. But the capacitance value can't be compared directly with other types of pickups - that would be an apples to oranges comparison.
  8. DHart
    Scottsdale, AZ USA
    By peak, do you mean the frequency at which output is the greatest will be higher?
    Or do you mean that the peak frequency itself will have higher output level?
  9. rigatele
    The resonant frequency is largely independent of the load resistance value. The effect of a higher resistance volume pot is mostly an increase in the amplitude, the frequency may shift slightly but almost immeasurably. To be unambiguous, I would refer to the Q but that term isn't as well known. To illustrate this point, I show a simulation of the Phoenix, with the equivalent loads that would be produced by 250k, 500k, and 880k pots:
    The actual peak responses are much lower, because of eddy current losses. However, you can see the general effect of the response.
    Green = 250k Blue = 500k Red = 880k
    As you can see, the frequency doesn't change much, only the amplitude of the peak.
    Ignore the red, green and blue dotted lines They are the phase response, not relevant here.
  10. DHart
    Scottsdale, AZ USA
    Gotcha... resonant peak stays about the same frequency, but the volume (amplitude) is increased, making it (and other similar frequencies) more "present" to the ear.
    4 kHz is a pretty high frequency (as far as human hearing goes), but plenty audible. That's the "sparkle" is do enjoy. :lol:
  11. Tommyd55
    Tommyd55 Tele-Holic
    Southern Louisiana
    Anyone have a comparison to the SD JD? I kinda liked that Oildale vid demo..
  12. Mark
    Mark Tele-Meister
    Englewood,FL
    The 51/52 is my favorite bridge pickup also. I have in 2 teles, a Nashville Lion in another and a Nocaster Holy Grail on the way. Rob is the man!
    DHart and BrewerDoer like this.
  13. DHart
    Scottsdale, AZ USA
    Indeed - Rob's pickups sound absolutely wonderful!
    BrewerDoer likes this.
  14. ndcaster
    ndcaster Poster Extraordinaire
    Indiana
    his Fat Lion was just the ticket for a powerful ceramic neck pickup
    I'd buy again
  15. Mark
    Mark Tele-Meister
    Englewood,FL
    I couldn't agree more.
    DHart likes this.
  16. Mark
    Mark Tele-Meister
    Englewood,FL
  17. Mark
    Mark Tele-Meister
    Englewood,FL
    Damn. I'm right there with you.
    Bruxist likes this.
  18. DHart
    Scottsdale, AZ USA
    Oildale is a suburb of Bakersfield, where a certain flavor of country music was cultivated.
    Bruxist likes this.
  19. SPUDCASTER
    Grangeville, Idaho
    Seems like the Oildale and the 51/52 will be reasonably close to each other.
    I have a 51/52, several Nashville's and a Bakersfield/Fat Twin Lion. Not sure I will need the Oildale, but who knows?
    Rob "IS" the man.
  20. DHart
    Scottsdale, AZ USA
    To a sensitive measuring device, Oildale would be ever so slightly brighter, with ever so slightly less midrange than 51/52.
    But the differences are so slight that to the human ear, in use, it would be unlikely that you could identify one from the other, except perhaps in extremely well-done, scientifically crafted A/B testing (exact same guitar, exact same reproduction parameters, etc.). And even then, doubtful you'd easily hear the difference. Differences in how a player picks the strings, even when trying to pick exactly the same way, would account for more apparent sonic difference, to the human ear, than the pickups themselves.
    If you have one, do you need the other? Not if you are looking for a different sound, no. If you just need another bridge pickup to put in another guitar, sure - get the other one.
    Bruxist likes this.
