Cathode DPDT switch On Off On
Discussion in 'Shock Brother's DIY Amps' started by XTRXTR, Apr 11, 2021.
  1. XTRXTR
    XTRXTR TDPRI Member
    Northern Colorado
    I know this sounds remedial but I want to setup a DPDT switch to test two different cathode bias circuits.
    The DPDT is ON Off ON.
    Is there any damage I can cause to the 12ax7 when it passes through the Off which is open circuit at that point? I can't put a ground or a resistor as the two ONs will always be in parallel. I don't want to ruin good tubes just to find out either.
    Thanks
  2. corliss1
    Lansing, MI
    Nope. Might make a pop, but won't hurt the tube.
    Tons of amps do this to implement a switchable gain boost.
    XTRXTR likes this.
  3. XTRXTR
    XTRXTR TDPRI Member
    Northern Colorado
    Thanks for the help, and the quick response. I'm going into the basement to implement the switch now.
