Cathode bias checking techniques
Discussion in 'Glowing Bottle Tube Amp Forum' started by bluerolo, Dec 9, 2019.
  1. bluerolo
    bluerolo TDPRI Member
    NJ by the sea
    Hoping for some help/opinions on how best to determine dissipation on a cathode bias amp. Working on a Harmony H415, 2x el84. I found a thread here that gave an easy to complete method, but then compared readings to other methods and came out with different results. Shooting for 100% dissipation at idle.
    Method 1 was:
    a. measure voltage from pin 3 el84 to ground...10v
    b. divide pin 3 voltage by the cathode resistor value...10/129 ohms = .0775ma
    c. measure plate voltage pin 7 to ground = 333v - cathode voltage of 10v = 323v
    d. 323v x .0775ma = 25.03W
    e. 25.03w/2 = 12.59w per tube...on a 12w max dissipation tube.
    Method 2 was Rob Robinette's website based calculator that used:
    a. Plate voltage pin 7 to ground = 333v, cathode voltage to ground = 10v
    a. plate to cathode v = 323
    b. plate current (which I assumed meant pin 7 el84 to pin 8 5Y3) = .033ma
    c. .033ma entered into his calculator = dissipation of 10.8w or 89%
    So as you can see if I'm trying to get 100% dissipation at idle for cathode biased amp I've got 2 conflicting measurements ...am I doing something wrong?
  2. Snfoilhat
    Snfoilhat Tele-Afflicted
    Oakland, CA
    Method 1 is missing a step.
    Once you've calculated cathode current (77.5 mA), you have to account for what portion of the cathode current goes through the plates and which portion goes through the screens.
    Rob's calculator automatically calculates something like 95% of the cathode current goes to the plates and 5% goes to the screens for some power tubes, and something like 90% of the cathode current goes to the plates and 10% goes to the screens in some other power tubes. These are estimates based on the tube data sheets of different tubes.
    77.5 mA for a pair of EL84s sharing the cathode resistor. Divide by 2.
    38.8 mA for a single EL84. That's the cathode current. Multiply by 90%.
    34.9 mA plate current. Multiply by plate-to-cathode voltage.
    11.3 W
    11.3 W / 12 W = 94%
    ^^^ that's my math. Here's what the calculator on Rob's site says with the same input:
    98%. Pretty close.
    King Fan and rolandson like this.
  3. peteb
    peteb Friend of Leo's
    Cascadia
    This sounds right, and you are very close. The plate current is 5-10% less than the cathode current.
    Every thin in method 2 sounds fine, except how did you determine that the plate current is 0.033? This should be 90-95% of the cathode current.
  4. bluerolo
    NJ by the sea
    Thx for the replies...my assumption, although it's a layman assumption, would be the most accurate method would be by actually measuring plate current since given all associated components are the same any given tube will measure a different current...right? I measured plate current by probing between pin 7 el84 and pin 8 5y3. This method results were 89% ...is this the correct way to measure actual plate current?
  5. peteb
    Cascadia
    That sounds like the shunt method.
    You measured current between the plate and the rectifier tube? Bypassing the output transformer?
    This method is known to provide quick and accurate results. I have tried it and it does, but it may read a little low, but not low like you got.
    What you really want is plate current to get the plate dissipation, not the cathode current, like SNfoilhat said.
    I think it is nice to check cathode current and plate current to cross check.
    A good way to find pate current is measure the DC resistance of the OT primary when the amp is turned off then measure the DC voltage drop across the same when the amp is idling, divide per ohms law and find the current.
  6. bluerolo
    NJ by the sea
    Isn't measuring from the plate (pin 7) to rectifier providing me with plate current...tube #1 measured 33ma tube #2 measured 33.5ma
  7. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    I don't know that amp, and I don't know the el84, but is there a reason you can't use Rob's cathode resistor voltage drop method? One measurement, or two if you want to get all fancy, and you're done.
  8. peteb
    Cascadia
    If the plate current isn’t 5-10% lower than the cathode current then something is wrong or the measurements are wrong.
    You could also check the screen current. Cathode current equals plate current plus screen current.
    Or, just do the transformer resistance method. It is the most trusted.
  9. gusfinley
    gusfinley Tele-Holic
    SLC, UT
