Catalinbread 18v question please
Discussion in 'The Stomp Box' started by CaineIsCarter, Jul 11, 2019.
  1. CaineIsCarter
    CaineIsCarter Tele-Meister
    Newcastle
    Hi folks
    Bought a Catalinbread SFT; it arrives tomorrow.
    I’ve read bits and pieces about using an 18v adapter for this pedal. Can someone please explain why this might be a good thing, and whether it’s worth it for a home player?
    Edit: just noticed my power supply has a 500ma/18v DC out - is this suitable?
    Thanks
  2. Jimmy Dean
    Jimmy Dean Tele-Afflicted
    Portland, OR, houseboat
    It increases the head room. I did not find the increased voltage to be that much of an advantage for my playing. It is a very good sounding pedal at 9v.
    CaineIsCarter likes this.
  3. CaineIsCarter
    Newcastle
    Thanks a lot
  4. tlsmack
    tlsmack Tele-Afflicted
    Lonk I-lant, New York
    Generally, the 18 volt option on drive pedals gives a slightly more open, less compressed feel. At low volumes, it can be hardly noticeable. I see you have an 18 volt supply. Let us know what you find!
  5. Jimmy Dean
    I think the current draw is 35MA. Your 18v supply should work just fine. Have fun.
  6. Rayf_Brogan
    Rayf_Brogan Tele-Meister
    I have their Echorec pedal and using an 18v adapter gives the repeats a little more oomph. Not noticeable at all in a live mix so I stick with the 9v.
  7. Pajama
    Pajama Tele-Meister
    I have found that the only pedals I like with more juice are delays. I think compressors and dirt pedals generally don't sound better w/ 18 volts and prefer them with 9 (or less, in the case of some fuzz pedals). Ymmv, but of course.
  8. CaineIsCarter
    Newcastle
    My SFT arrived and I had five minutes with it at lunchtime. I felt slightly underwhelmed, but of course I’ll need a lot more time to get it dialled in.
    I’m looking for a Brown Sugar sort of tone. To those of you who have this pedal, do you have any recommended settings? Is it best used in front of a clean amp (Blues Jr), or on the edge of breakup?
    I’m looking forward to having a proper play with it this weekend, but any suggestions would be very welcome.
    Cheers
  9. tlsmack
    Howard doing the demo is also the designer, he has several SFT videos on youtube! DId someone say Brown Sugar?!
    Obsessed and CaineIsCarter like this.
  10. CaineIsCarter
    Newcastle
    Thanks, I’ve seen that video before (it was the reason I wanted an SFT) but I wish I knew what his amp settings are. I assume it’s clean but can’t be certain.
  11. tlsmack
    Usually Howard sets his Princeton pretty clean and lets the pedal act as the amplifier.
  12. CaineIsCarter
    Newcastle
    Had a really good play with the pedal this weekend and learned a lot about my amp in the process.
    With the amp MV wide open and the volume at about 2, I get a lovely clean tone which I can then control with the SFT.
    The sound of a Tele through this setup is addictive, and I get the Stones sound I’ve always wanted. Very pleased.
    santiago53, Obsessed and tlsmack like this.
  13. TheTruth
    TheTruth TDPRI Member
    India
    Overall higher voltage in general implies:
    - OD: More headroom, feels bigger, gradual clean range.. better clarity/dynamics , a lot of people say at higher voltage, it starts to sound less like a pedal & more amp-like.
    - Compressor: Mostly a volume boost & some added clarity at really low vol [Wampler forum mentions this with the Ego compressor]
    Since I tried my OCD at 18V, I since started using the Timmy/ TS808 / EQ pedal & compressor, all at 18V.
    It's worth trying.
    The one place it may not work is when you're looking for compression, intentionally.
