Puddles
Hi all,
Recently I was given a Carvin Nomad that apparently is relatively new however wasnt working - I accepted it assuming I'd be able to sit down and work out what was wrong with it. Without having ever owned a tube amp, I thought it might be a nice addition if I could get it working. Inherently this also means I don't have much experience with these things, so please bear with me...
Turns out there was a cracked preamp tube (12ax7) so I thought alright, I guess that's all that's needed. So I went out and picked up a new tube and put it in.
Sure enough - sound! Sweet. Plugged in and had a play, sounded good, nice and warm compared to my solid state Fender M-80.
Two days later, I switch it on, lights come on, warm hum rolls in and I go to play again - nothing.
Cutting the story short - It looks like only the tube in the socket that I replaced is glowing while now none of the other ones are. I don't think the tubes are bad as I switched each one into the working socket and they all took turns lighting up while the others didn't.
The tube position in question is the furthest one away from the input.
There's a faint hum and what sounds like the ocean rolling in the distance.
The only other things I can provide is that the amp hadn't moved since I got it working. I did accidentally leave the power on (but on standby) for a few hours after playing before I realised. I have tried another speaker resulting in the same symptoms. I have also tried plugging directly into the FX return to no avail.
I'm not too bad with a multi meter, but I work on cars normally, so PCB's are a bit unfamiliar territory - is there anything else I can try or test?
