Car Trouble
Discussion in 'Bad Dog Cafe' started by chet again, Jul 3, 2019.
  1. chet again
    chet again Tele-Meister
    iowa
    I've been expecting this car to break down given the high mileage. I'm just trying to do some cheap fixes to keep it running a couple of months. I plan on getting another Versa later this year cause I've had 2 and they both ran trouble-free for a long time.
  2. dented
    dented Poster Extraordinaire Platinum Supporter
    Back at the Beach
    It sounds like Versas are your vice....or vice Versa. :rolleyes:
    Nightclub Dwight, sean79 and skunqesh like this.
  3. mojavedesert
    mojavedesert TDPRI Member
    29 Palms, CA
    Look under the oil cap, if it looks like a cappuccino froth, you have a blow head gasket. It would have not have a lot of compression. A higher speeds might see to run fine. Eventually it will overheat. Sorry to be the downer guy.
  4. william tele
    william tele Doctor of Teleocity Ad Free Member
    Kansas City, MO
    Did I miss where he had the codes read?
    If not...it could be anything...literally.
    Any number of sensors, cat, crank position sensor...anything. If the light flashed you're lucky you made it home. You're right, usually it indicates a spark failure and may have put you in "limp mode".
  5. chet again
    iowa
    I took the car to the parts store again and had a kid hook the tester up again so I could see for myself what it came up with.
    Cylinder 4 was misfiring
    It also had a O-Sensor fault.
  6. Guitarzan
    Guitarzan Poster Extraordinaire
    Hotlanta, GA
    Yes. It's a Nissan Versa.
    You are welcome. :D:p
  7. Guitarzan
    Hotlanta, GA
    Does it have a coil on plug?
    Is the fix to replace a C.O.P. and spark plug?
    Can you pull the sensor out and inspect and clean it?
  8. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Bakersfield
    It is placed in there to discourage all but the most able home mechanic from doing anything but to take the car to (hopefully) an authorized dealer for repair.
    Piggy Stu likes this.
  9. Toto'sDad
    Bakersfield
    If you have an O sensor fault, the engine might not run right even after changing out a bad spark plug. I had a Chevy pickup that I let the plugs go too long before changing, the O sensor got confused, and I had to drive the pickup several miles after changing the plugs before it would run right. The problem eventually corrected itself. I didn't have to change the O sensor. I could easily have had to though. I know for sure when the O sensor is not working correctly, the engine would hardly run.
  10. 1293
    1293 Poster Extraordinaire
    Coil pack was my first thought.
  11. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    If this thread has done one thing, it’s confirmed my belief that I’m doing the right thing leasing cars and letting the dealer worry about lights, warnings, maintenance, and even my Thursday car wash.
    Toto'sDad likes this.
  12. Toto'sDad
    Bakersfield
    That's the general idea among those who provide leasing. My daughter has been leasing for her last two, maybe three vehicles. She drives a company car most of the time, and only uses her own car on the weekends. They're saying they may break the cycle this time, but when it comes time, will probably cave and just get another lease car.
  13. Toto'sDad
    Bakersfield
    We drive very little, and bought new cars years ago. I just ran the numbers on my CRv, it's down to a cost of about 231 dollars a month. The wife's car is clear down to 110 dollars a month. These numbers are for the life of the cars. A lease makes sense for some, not for everyone. We paid cash for our vehicles, and did not incur any interest. I'm in hopes we never have to buy another car. If we do, we will pare down to one. Leasing at that time might make sense for us too. Since generally we have paid cash for our cars, a lease would allow us to keep the cash, and we could probably get a decent car for a pretty low monthly outlay. Kind of thinking as I wrote.
  14. JL_LI
    Long Island, NY
    My wife and I have two cars. The BMW is on a lease. It's my fourth BMW lease after four Volvo leases. You don't want to own a BMW a day after the warranty expires. I bought the SLK for my wife because it's not driven too much, 35,000 miles in 5 1/2 years. We've only had maintenance so far. We replaced the performance tires with all season tires because we don't race and all season tires are safer in the winter. So far so good. I'm looking forward to an end to car payments next March. That's the argument for purchasing. There comes a time when it's finally paid for. Now all I have to do is keep my wife from shopping for a replacement.
  15. chet again
    iowa
    BMW?
    No thanx...
  16. chet again
    iowa
    Think I found the problem.
    I took out the easy spark plug and the gap was about twice as much as it should be. The one next to it was about as bad. Maybe they just wore off but I have both replaced. I need to get a gasket set for the intake manifold then I'il replace the other two.
    Torren61 likes this.
  17. guitarmojo
    guitarmojo TDPRI Member
    United States
    Just so you know, there's a lot of bad advice and misinformation in this thread. A bad plug might show up like yours did,but usually they wear at a "less than noticeable" pace. Sounds like you need plugs anyway, so no harm in changing them. But I wouldn't be surprised if it doesn't help.
    That said: Check Engine light does not mean your gas cap is loose. It means there is an issue in the engine management system. The gas cap is part of that system, so it could be the cap, but it could be a myriad of other problems as well. Getting codes scanned was good advice. But getting codes scanned is only the first step in diagnosis. Your #4 misfire could be a lot of different things: Blown head gasket, bad plugs, bad cam/valve train, etc.
    My best advice is to take it to a mechanic you can trust and build a relationship with him/her.
    Torren61, Piggy Stu and Stubee like this.
  18. schmee
    schmee Poster Extraordinaire
    It's a good thought regarding the catalytic convertor. How old is the car? I had one go out in my band van. First event was going up a hill with the cruise control on, it kept shifting down then it kind of lurched and I pulled over. Ran real rough for a minute then I limped home. Then it ran for a week or two just around town but seemed a bit gutless. Finally my mechanic said it was the CC. Replaced and car was great after that.
    This was at 130k miles. SO you may be well overdue. Not cheap either.
  19. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    There is a reason why fuel filters are put in the tank, but it's not nearly that ridiculous.
  20. william tele
    Kansas City, MO
    I've changed a couple fuel pumps. Managing a full tank is the biggest problem. If you work with a fairly empty tank its better...especially if you have to drop the tank. Some cars have a plate under the back seat or trunk area to access it.
    Stubee likes this.
