In a recent thread, @chas.wahl designed and built a testing device to silently switch the connections of a film cap connected to an amp for much quieter testing (no pops and roars from reversing leads) with much more instantaneous A:B comparison. See that thread for lots of good discussion:
https://www.tdpri.com/threads/checking-cap-foil-lead-polarity-w-o-oscilloscope.1126408/
For a deep dive on finding the cap outer foil, see Mr. Aiken, who uses a scope. For those of us who don't own one, testing by ear is an attractive idea. All you need is a cap, a plug, a couple gators, and an amp.
But it's a slightly tricky proposition: Don't forget to turn amp down while switching clips, do try to remember exactly what volume setting to return to, do try to retain exact memory of hum loudness.
In the recent thread, I was massively impressed by an idea from our smart friend @Peegoo , who figured out that a 'make before break' switch would do this without pops and roars, and (wait for it) that a 3-way Tele switch was just that. Most impressive of all, he figured out the wiring. Whatever else you do, see his post, which explains the wiring and shows how it works.
https://www.tdpri.com/threads/checking-cap-foil-lead-polarity-w-o-oscilloscope.1126408/post-11854587
I was so impressed I just had to build one. I re-drew his diagram to make sure I could get the wiring right -- you want to know which switch direction connects the sleeve of the plug to which test clip.
Anyway, here's the result. It works *great*... much easier and way quieter and *way more obvious* than twisting the volume knob while unclipping.
Thanks, @Peegoo. Next I'll try to work up a quick video demo.
