Can You Split a SD Little 59?
Discussion in 'Just Pickups' started by Mountaintwanger, Dec 31, 2013.
  1. Mountaintwanger
    Mountaintwanger Tele-Meister
    North of Seattle
    I'm looking to change the pup's in my 62 tele custom and was wondering if you can split the little 59 bridge pup with a push/pull volume pot? Also I'm thinking of a quarter pounder in the neck?
  2. Mountaintwanger
    North of Seattle
    BTW I want my tele to cover everything from chicken pickin to classic rock.
  3. 62 Jazzmaster
    62 Jazzmaster Friend of Leo's
    Steveston BC, Canada
  4. tresspassor
    tresspassor Tele-Meister
    Austin
    Yes, you can. I've done it and it doesn't sound that great.
  5. 62 Jazzmaster
    Your best sounding option might be a Series/Parallel switch, rather than coil split.
    That would give you a cleaner, brighter sound on Parallel and the stock, hotter sound on Series.
  6. Coop47
    Coop47 Poster Extraordinaire
    Boston
    That's what I have on mine - works pretty well, especially with 500k pots.. I think the split coil sounds a little thin.
    I have a P-Rails in the neck that I like a lot.
    However, I'd hate to mess up the looks of a 62 Custom with a Lil 59. My strong suggestion would be to add a four-way switch and have the pups wired in series for the fourth position. I have a 2005 American Series loaded with Don Mares wired this way and it handles everything I play in a cover band.
  7. telemaster7082
    telemaster7082 Tele-Afflicted
    Ottawa, Canada
    I used to have a SD hot rails, series/parallel in mine for the longest time. I know it doesnt get me ntioned a lot, but I used that pickup for everything. IMHO it is a great sounding pup. The Little 59 on the other hand....crickets crickets crickets.
  8. moosie
    Western Connecticut
    Yes, you can split it. I had this (split) pup in my Strat's bridge position for a while, and I'm surprised I left it for so long. Not at all impressed. Sounds nothing like a full size hb, IMO.
  9. YoGeorge
    YoGeorge Tele-Afflicted
    Michigan
    I'm not a fan of the lil '59 for most stuff. Split is really weak. Series is muddy and middy and clangy/hard with very little "feel" unless you have your amp on 11 and want to do pinch harmonics and weedly weedly solos. Probably my favorite wiring for it is parallel, so if you already have the pickup, go series/parallel.
    It does NOT sound like a big '59 bucker--IMO it sounds like a full size JB bucker, which I also do not like (whereas I do like the full size Duncan '59's).
    George
  10. Bartholomew3
    Bartholomew3 Friend of Leo's
    Montreal
    That's what I thought also after doing it.
  11. B.G.
    B.G. Tele-Meister
    California
    I likewise was unimpressed with the sound of the little '59 split, but I think it actually sounds best in parallel, so I'd strongly recommend giving that a try.
  12. soulman969
    Englewood, CO
    And my suggestion as well. To me if you do what you're thinking of OP you're messing up a good guitar and making it worse. JMHO
  13. voodoo tele
    voodoo tele Tele-Meister
    kansas
    +1 on series/parallel switch have one on one of my teles and love it!
  14. brenn
    brenn Tele-Afflicted
    Kentucky
    I would guess those tiny little coils would be pretty weak.
  15. brenn
    Kentucky
    You're describing a range of sounds that a normal tele is often used for, how about just some good Tele pickups, like a set of Rio grandes?
    Going another way, how about a pair of Gold Lace Sensors with a mid-raneg boost circuit, like a Clapton strat? James Burton, Clapton,. Buddy Guy, etc., have all used the lace sensors and with the Clapton boost, the start can sound like a Les paul, so I'd think the same would work with a Tele. I think Lace Sensors are the most flexible pickup out there.
    Third idea, if you want to play Danny Gatton and Duane Allman on the same guitar, is to put a full-size humbucker at the neck, with a coil tap. (OK, a neck humbucker on a tele won't ever sound like Duane Allman, but....)
