Can Someone Mod My Compressor?
Discussion in 'The Stomp Box' started by JeradP, Feb 10, 2011.
  1. JeradP
    JeradP Former Member
    michigan
    First off, I want want to make sure it is alright to post this here rather than somewhere else. I'm asking someone to mod my cheap compressor to reduce the noise. I'd be willing to pay of course. Just let my know if it's not ok to do so here.
    I have a Rogue Compressor I just recieved. It has a "ringy" noise to it, I guess is the way to describe it. I like the compression it has and the size is great. The volume (level) can't be turned up very high before it gets noisy. Too much noise. I know comps are noisy pedals. And I also know zilch about modding pedals myself. I know how to package them in a box, fill out a form, and have someone do it. I know, I've done it before... ;)
    I told the place I bought it from, and they said to keep it and they'd refund my money. I was shocked. So I thought I could afford to get it modded now.
    Would anyone/ could anyone help me and make the compressor less noisy? The sustain knob is irrelevant to me, it's only set to a level that doesn't reduce the volume really. I use the attack on full. It is a second compressor, I planned on using it with my Boss CS3 that I really like. If someone out there can give me a hand, I'd be greatly appreciative. Thanks :D
  2. JeradP
    michigan
    Here is a picture of the guts, if it matters at all
  3. LongLiveRock54
    LongLiveRock54 Tele-Holic
    Alabama
    Jerad, I have one of those too. I have found that sometimes its noisy, and other times it is not. I don't know if it is a matter of the guitar, amp, cable, power supply, wall outlet, pedal chain combo or what it is. I have several guitars and amps, so I'm thinking that might be part of my issue.
    When it wants to be quiet, I'm quite happy with it, and since I only paid about $29, I'm not too concerned.
    If I were you I would try different combination's of gear and cable set-up or you could have them send you a replacement or put the money towards a different brand.
  4. JeradP
    michigan
    I have tried a lot of combinations and so far nothing works. Other than keeping the level very low of course. They refunded my money and said to keep it, which I was very surprised at. Because of that, I'd like to try to put that money towards making it better rather than get a new one
  5. chrisgblues
    chrisgblues Tele-Afflicted
    Halifax
    I think you're better off getting a new pedal. You'd have to get someone to agree to trace the circuit, troubleshoot, and be able to work with SMC (Surface Mount Components). Many of the components including the chips are much smaller and more fragile than traditional components and are machine soldered to the surface of the board traces, not through-hole which is normally preferred...so this makes it very tricky to work on. It basically becomes a "throw-away" item.
    Basically, anybody with that level of skill and knowledge would probably have to charge you so much for their labour IF it can be fixed at all...that you would be better off getting a higher quality pedal in the first place.
    I'm not a repair guy, but I've followed it enough to know that's what you're probably faced with. JMHO. I could be wrong.
  6. Impulse
    Impulse Tele-Meister
    California
    Get something better, JeradP.
  7. JeradP
    michigan
    I figured that would be the case. I'll probably take it to a pawnshop and get what I can for it. Thanks
  8. JeradP
    michigan
    I forgot I had a Digitech wal wart, so I tried that. And so I have 2 compressors on my board now... :D
