Can someone explain this?
Discussion in 'Tele-Technical' started by sacizob, Feb 27, 2013.
  1. sacizob
    sacizob Friend of Leo's
    Middlesex County, MA
    The following is from the questions page of the November 1993 issue of Guitar Player magazine.
    Question: The neck on my 1963 Stratocaster is too straight, even with the truss rod completely loose. Can this be a corrected?
    Answer: Guitars usually need some bow to play correctly. John Page of Fender Custom Shop informs us if no relief exists when the strings are brought up to pitch, the neck must be tightened to an overbow, then resanded and refretted. This is complex surgery: so consult a qualified repairperson.
    (Why resanded and refretted?)
  2. Frodebro
    Seattle
    If you tighten it to the point of overbow and then re-sand and refret it, once you loosen the truss rod back up the fretboard will have the relief it needs.
  3. Peltogyne
    Peltogyne Tele-Afflicted
    Northern California
    Cause you can't sand under a fret ;)
    Sometimes you can just overbow the neck and then file the frets, you get lower frets in the middle of the neck but it can work. I think a better way to deal with this is use the mild thermoplastic properties of the wood and heat and bend it.
  4. Jupiter
    Osaka, Japan
    Sand and re-fret a '62 strat? :eek: I wonder if they'd give the same advice today.
    Answer: Change those wimpy .09's for .11's! :D
    Man, I'd try a lot of different stuff before I'd have somebody do that to a vintage guitar neck.
  5. Ed Miller
    Ed Miller Tele-Meister
    Coldwater, MI
    heat press.
  6. Nick JD
    Queensland, Australia
    Take the neck off and clamp it to a bench for a week forcing forward bow (relief) into it.
  7. Bartholomew3
    Bartholomew3 Friend of Leo's
    Montreal
    My 68 tele bowed too much over the years - best solution is to use 10.5 or 11 - it pulls back to where it should be.
  8. Peltogyne
    Northern California
  9. dadder
    dadder Tele-Meister
    Northern Ireland
    Nick JD is right here, just remember to slacken the truss rod nut right off before you clamp it. Never failed me yet.
  10. Doug 54
    Doug 54 Poster Extraordinaire
    Ohio
    Heat press first, yes!
    Last resort, the sanding, etc.
