Can I use 125BSE in place of 125B for output transformer?
Discussion in 'Shock Brother's DIY Amps' started by dantahoua, Sep 18, 2020.
  1. dantahoua
    dantahoua TDPRI Member
    Quebec
    Hello!
    I bought 3 years ago all the stuff to make a Bassman Micro. I finally have the time to make it (and I choose to make the LTP one). I'm not that good with all the power part of the amp (but very good with the Preamp part :) ).
    I just notice the Output transformer I received 3 years ago is the SE one and not the regular one.
    Can I use it in the Bassman Micro? I was about to wire the black and green to the speaker jack (8ohm) when I noticed it is not the same color @robrob was describing in the "tutorial"...
    Thanks for your time! :)
  2. zook
    zook Friend of Leo's
    Cochise, AZ
    They are different in that the `125B is for a push-pull circuit and the 125BSE is a single ended OT.
    That being the case, they can not be substituted for each other.
  3. dantahoua
    Quebec
    Gosh... I'll have to order a good one and this one is no use to me... :(
    There is no way I can use it with this layout?
  4. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    The 125BSE has two primary connections: B+ and plate. You need 3 for a push-pull amplifier: B+, Plate (push) and Plate (pull.)
    Game over. Sorry!
    Save the 125BSE and make a Champ someday, it'll come in handy.
    awasson and dantahoua like this.
  5. radiocaster
    europe
    You could if you rewire the phase inverter as a regular preamp stage, and the power triodes in parallel.
    awasson and Wally like this.
  6. dantahoua
    Quebec
    Very interesting! Would love to see how to do that. But anyway, I'll follow @tubegeek suggestion and keep it for a small champ or something like that SE amp. I'm a guitar maker, not an amp maker, this amp will be just for my shop to test my guitars! I do not want to spend that much time on it. :)
  7. dantahoua
    Quebec
    Would go with the 125B(5W) or 125C(8W) knowing that I'm more a peamp overdrive than a power amp overdrive guy and I'll pair this small amp with another 22W 6V6 amp for stereo (but at very low volume). ? And I will use a 12BH7 as power tube and I play baritone guitar. :)
  8. tvas22
    tvas22 Tele-Meister Silver Supporter
    dantahoua likes this.
