Can I Store a Tube Amp on its Side?
Discussion in 'Amp Central Station' started by TelecastrMastr, Jun 9, 2021 at 10:50 PM.
  1. MilwMark
    near Arnold's
    Man. Y’all worry about some weird ****.
    It’ll be fine. How do you think amps get from the factory to stores? Teleportation?
    Have you ever looked inside a tour bus or van? It’s like Tetris in there.
    And on tour there is no way to keep gear in carefully air conditioned pristine indoor conditions.
    It’s robust gear that survives robust conditions just fine.
    Lynxtrap, Tim S, AAT65 and 3 others like this.
  2. magicfingers99
    magicfingers99 Friend of Leo's
    atlanta
    Nope, all the electricity will leak out, if you have a reverb tank and its not sealed, all the reverb will leak out. All the magnetism on the speakers go to one side and then your speaker will be out of phase.
    pluse any cockroaches or other vermin will be disoriented and likely to complain...
  3. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Bands ship their gear in tractor trailers. Yes it gets hot, but not enough to be a problem.
    Geo likes this.
  4. drmmrr55
    drmmrr55 Tele-Holic
    Federal Way, Washington
    Anyone remember that old Vox commercial, where they kick one down a flight of stairs, (I think it was an AC15), and plug into it right after, and it worked just great? I think most tube amps are actually pretty rugged...
    northernguitar likes this.
  5. magicfingers99
    atlanta
    you could break a toe doing that...
  6. Guitarteach
    you must work for one of those audiophile cable companies... you got all the science
    Pcs264 and magicfingers99 like this.
  7. Phrygian77
    Crawfordville, FL
    Anything that can't handle 85C doesn't belong in a tube amp.
  8. afterdarkmusic
    afterdarkmusic TDPRI Member
    Corvallis, Oregon
    I did this once. All the mojo leaked out. Would not recommend.
  9. bumnote
    bumnote Tele-Holic Ad Free Member
    Northern Virginia
    I wouldn't be concerned with the tubes at all. They've been used in all sort of planes, trains & automobiles in the past mounted upright, upside down & sideways. Just check them when you arrive.
    However, my concern when transporting an amp is the speaker & the baffle. I always place it face down so the weight of the speaker isn't putting strain on the baffle or the screws holding it in place. Potholes are everywhere here & while I'm sure the little amount of time my amps are actually in a car isn't much to be worry about, why risk it. It's cheaper and easier to replace a tube that might slip out & break when the jolt that could cause that to happen could just as easily damage a speaker & baffle.
  10. magicfingers99
    atlanta
    wrap it in plastic real good, and stick it in a shipping container full of lime jello. if it gets damaged in transit, you can still enjoy the lime jello.
  11. Red Ryder
    Red Ryder TDPRI Member
    Tuesday
    Sulphur Springs Tx.
    It's not really advised, something about the freon in the compressor and cooling tubes getting screwed up.
  12. Red Ryder
    Tuesday
    Sulphur Springs Tx.
    That is excellent advice.
    radiocaster and magicfingers99 like this.
  13. guitar_paul1
    guitar_paul1 Tele-Meister
    washington state
    Store yes, play no. I was always told the plates don't get rid of their heat properly when running on the side.
  14. Lynxtrap
    Lynxtrap Tele-Holic
    EU
    On the other hand, one could think it was the opposite. Heat travels upwards, and the largest surface area would face upwards with the tube on the side. Hanging would be worst in that regard.
