Can I A/b/Y speaker cabinets?
Discussion in 'Amp Central Station' started by Chet Johnson, Apr 8, 2012.
  1. Chet Johnson
    Chet Johnson Tele-Afflicted
    Woodsfield, OH
    I got a relic tweed Blues Jr. Yesterday, and a lacquered tweed extension cab.
    I thought that the blues junior would have an extension speaker jack, but it only has the jack for the internal speaker.
    Can send the amplifier output into an A/b/y box, and select between the internal open back speaker, and the closed back speaker cabinet? Also, can I use the Y on the box and run both 8ohm speakers at the same time without amplifier damage?
    Thanks!
  2. celeste
    celeste Friend of Leo's
    Maryland
    Yes, there are A/B/Y speaker switching boxes. it is usually done with relays close to the amp and speakers and the relay control run out to a floorboard switch. Weber is the least expensive I know of.
    If you don't mind doing it manually, you could use a switch intended for impedance switching
  3. Mike H.
    Mike H. Tele-Afflicted Silver Supporter
    Collierville, TN
    Just get one of these. Much cheaper than a splitter box.
  4. Chet Johnson
    Woodsfield, OH
    actually in this case , I already have the ABY box and was hoping to use stuff that I had and come up with some new trick.
    If I use the Y cable and run both 8ohm speakers simultaneously, do I risk anything on the amplifier?
  5. celeste
    Maryland
    your output tubes will wear out a bit faster, but it would surprise me it it is noticeably faster.
    If the A/Y/B box is a stomp box, make sure the switch is rated for the current.
  6. Mike H.
    Collierville, TN
    You can safely run Fender amps at up to 100% impedance mismatch.
    An 8 ohm output transformer will handle 4-16 ohms with no ill effects.
    Just be sure you don't run the amp without a speaker load or you will kill the OT.
  7. 5595bassman
    5595bassman Tele-Holic
    Montreal Canada
    You will need this type of ABY switch :
    http://www.tonebone.com/tb-cabbone.htm
    A regular ABY switch is not safe enough. It have to be "connect before disconnect" type in order to avoid any gap in power feeding that will result in a no load situation. Doing such even for a very short period is dangerous for the OPT, moreover when the amp is running at high level.
    Edit: I just noticed that this Radial switch not even do the "Y" part of your request!!!! And the price is pretty high.
