Can Gotoh split shaft tuner buttons be changed?
Discussion in 'Tele Home Depot' started by V Silly, Jan 21, 2015.
  1. V Silly
    V Silly Tele-Meister
    Santa Barbara CA
    Hello folks, just discovered I may have a nickel allergy and all the tuners on my guitars are Gotoh split shaft nickel. I really like split shaft tuners and do not want change to solid shaft. It does not look like the tuner buttons can be changed but thought maybe I just don't know how it is done? My other brilliant idea is to dip the tuner buttons clear plasti-dip which is the plastic coating used to make tool handles.
    Luckily I have stainless frets and have started experimenting with nickel free strings. Not sure the brief amount of time I spend touching tuner buttons is going to be an issue but it might be a good idea to eliminate as much nickel as possible.
    Thanks for any feedback, all the best.
  2. guitarbuilder
    How about painting them with clear nail polish or lacquer? Maybe superglue?
  3. mojo2001
    mojo2001 Tele-Holic
    DC
    I don't know about changing buttons, but the Gotoh SD91s are available with other knobs. I just bought a pair of white plastic button Gotohs on ebay and the factory catalog lists a few other non-nickel options.
    Seller on the white button jobs was "johnnyshades."
    The plasti-dip idea might work though. Whattya got to lose trying?
  4. Glen Smith
    Glen Smith RIP
    How about a few pairs of thin cotton gloves in your gig bag?
  5. allen082
    allen082 Friend of Leo's
    fort worth
    I'm allergic to nickel but have never had any issues with anything guitar related (strings, hardware, etc). Make sure they're actually causing you problems before you invest money on something different.
  6. V Silly
    Santa Barbara CA
    Only problem with SD91 Gotoh is the ones with plastic buttons are not available staggered as far as I can tell. Have enjoyed not needing spring trees...
  7. Vizcaster
    Glen Head, NY
    Unless you're using the tuning machines as pierced-earrings, you shouldn't have an issue. Ask your allergist. Do you have a problem with buttons, snaps, zippers, or faucet handles?
  8. V Silly
    Santa Barbara CA
    It's kind of a new development so not sure about what the triggers are. From reading anecdotes of others with nickel allergy, it can develop after years of not having a problem. Or in my case it might not be the nickel at all, but I changed to nickel free strings and the rash seems to be clearing... so...? If you look up causes of contact dermatitis it seems it can be triggered by many thousands of things.
  9. lbridenstine
    lbridenstine Friend of Leo's
    Kalamazoo, MI
  10. telemnemonics
    You could probably just give them a couple of coats of spray poly, if you can't change them.
  11. V Silly
    Santa Barbara CA
    Thanks everyone, I think that I have good ideas here, best regards
