Can a Tele Amer. Deluxe accept any Tele neck?
Discussion in 'Tele Home Depot' started by DHart, Dec 15, 2014.
  1. DHart
    DHart Friend of Leo's
    Scottsdale, AZ USA
    I think that the Stratocaster American Deluxe requires a Deluxe neck to fit the cut-away heel pocket correctly, right?
    Does the Tele American Deluxe also require a Tele Deluxe neck for proper fit, or can any correct-spec Tele neck fit on the Tele Deluxe body?
  2. justin72deluxe
    justin72deluxe Tele-Meister
    Oklahoma
    I have a 72 deluxe reissue with the universal neck pocket. It would except a tele or strat neck. Not sure if this answers you question.
  3. DHart
    Scottsdale, AZ USA
    Thanks, Justin. It sounds like a Tele Deluxe neck pocket has the same specification for a Tele neck fit as any other Tele, right?
    No, I wasn't asking if the Tele Deluxe can accept a Strat neck.
    I just wanted to know... if I bought an American Standard Tele Deluxe BODY, would the neck from any other Tele model fit the Deluxe body? Or does a Tele Deluxe body require a Tele DELUXE neck?
    Hopefully someone with more experience on this than I can confirm.
  4. justin72deluxe
    Oklahoma
    As long as they both use the same mount style they will. If it's a standard 4 screw mount use the same. Same goes if its micro tilt style. All standard Tele necks have the same neck pocket dimensions.
  5. DHart
    Scottsdale, AZ USA
    Thanks, Justin. I appreciate your help!
  6. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    The only two I can think of that are different are the Modern Player and the Squier VM Thinline.
