When you say to connect one end of the resistor to the hot lug, do you mean the toggle switch?
Solder the resistor to the two outside lugs of the pot you want to reduce. Use a 470K resistor. I have done it on a number of occasions it works.
A resistor in parallel with the pot can change (lower) the apparent value, and for a 500k pot a 470k resistor is about right.
1/Rt = 1/R1 + 1/R2 = 1/500k + 1/470k > Rt = 242k
This trick is typically used to make single coils "see" ~250k when teamed up with a humbucker.
Attach the resistor to the hot lug of the switch corresponding to the pickup you want to see 250 and the other end to ground. With a superswitch you can isolate the resistor to specific positions a lot better than with a standard switch.
Yes I use a 249 or 270k. Fender has a diagram for this using a 270k resistor on a Tele with a neck Humbucker and Tele Bridge using two 500k pots. Adding the 270k resistor to the Tele Bridge which makes the bridge see the circuit as apprx 250k pots.
This will be a whole lot easier if you just swap out the 500K pots for 250Ks. You can add parallel resistors (as discussed) but the results will not be quite the same, especially with regards to taper.
^this. It will only be the proper overall resistance when the pot is turned all the way up. It will significantly change the taper of your pot(s) for anything that is not full bore.
